ᐅ Central room temperature controller for the fan coil unit (FCU) of the underfloor heating system
Created on: 23 Jun 2020 11:34
micric3Hello,
Is there a way to control the ERR centrally on one device, so that, for example, the children cannot adjust the underfloor heating control (heating circuit)? Also, I don’t mind not having a thermostat with a controller in every room. What would be the alternative? Are there sensor-only devices that, for example, send the temperature wirelessly to the central unit, or does a separate fixed setting for the respective heating circuit also count as an ERR?
Good luck
Good luck
StevoBrun23 Jun 2020 12:09Hello,
which heating system is installed? Gas? Heat pump?
Regards
Regards
T_im_Norden23 Jun 2020 13:44Shut off the ERR and adjust the temperature using the heating curve.
@Mycraft I have an appointment with Vaillant on Thursday.
@T_im_Norden: I would like a more detailed explanation of this topic “ERR shutdown.” If the room thermostat is set to 25 degrees Celsius (77°F) but the heating itself is set to 21 degrees Celsius (70°F), then everything runs at 21 degrees Celsius (70°F). Have I understood that correctly?
