ᐅ Central room temperature controller for the fan coil unit (FCU) of the underfloor heating system
Created on: 23 Jun 2020 11:34
micric3
Is there a way to control the ERR centrally on one device, so that, for example, the children cannot adjust the underfloor heating control (heating circuit)? Also, I don’t mind not having a thermostat with a controller in every room. What would be the alternative? Are there sensor-only devices that, for example, send the temperature wirelessly to the central unit, or does a separate fixed setting for the respective heating circuit also count as an ERR?
Good luck
T_im_Norden
21 Sep 2020 19:15
Ask your heating installer for the cheapest solution for actuators and thermostats.
Then remove the thermostats from the wall and install a blank cover so nothing is visible anymore.
Controme is a system that claims to control the heat pump for each individual room.
If you have understood the posts here, it should be clear to you that this is not possible with a standard home installation.
Daniel-Sp
21 Sep 2020 20:29
micric3 schrieb:
Does anyone know about the underfloor heating control system from Controme?
Here, temperature sensors are mounted directly on the return flow at the heating manifold for immediate temperature feedback. Would this make a thermostat inside the room unnecessary?
Most heat pumps are controlled by the return flow, so why would you install an additional return flow control system?
Mycraft22 Sep 2020 07:19
Well, that is overengineering at its best.
micric3
25 Sep 2020 06:57
Mycraft schrieb:
The cheapest option available, why throw more money out the window than necessary?
For the underfloor heating actuators, I only found systems from Homematic. Actuator 190, actuators around 20 EUR, and thermostats around 45 EUR.
Does anyone know of other systems?
Mycraft25 Sep 2020 08:56
Möhlenhoff Stellantrieb Alpha 5, for underfloor heating, NC, including 1x adapter ring VA80 ~ 10 euros each
MÖHLENHOFF R20203-10N4 Alpha room temperature controller 230V analog ~ 16 euros each
MÖHLENHOFF B 21402-06N2 Alpha system base station, 230V, NC, neutral 6 to 10 zones ~ 50 euros
micric3
25 Sep 2020 10:43
Thank you. Unfortunately, these are not the wireless versions. The Alpha 2 also costs around 200 EUR.
