ᐅ Bungalow Floor Plan Design in Brandenburg
Created on: 5 Jun 2022 22:57
Crax237
Hello house building enthusiasts,
After going through numerous catalogs and floor plans, we have come across two floor plans in this forum that appeal to us much more than the ones in the catalogs.
Could you give a recommendation on which floor plan would make the most sense for the plot linked below?
Development plan: none / restrictions
Plot size: 1400 sqm (0.35 acres)
Slope: no
Site occupancy index: 0.4
Floor space index: 2
Building setback line / building line / building boundary: 3 m (10 feet)
Number of parking spaces: double garage
Roof pitch: 25–55 degrees
Maximum heights / limits
Additional requirements
Client requirements
Architectural style, roof type, building type: bungalow with hip roof or gable roof
Number of occupants, age: 2 adults and 1 child
Space requirements on ground and upper floors: see floor plans
Open kitchen, kitchen island: kitchen island
Number of dining seats: 6–10
Fireplace: yes
Thank you to the forum members for sharing the floor plans. We have attempted some amateur modifications based on our ideas.
Would you recommend a different building type?
The direct neighbor has built a 1.5-story house directly on the 3 m (10 feet) boundary line. We do not yet know what kind of house will be built on the southern part of the available plot.
All floor plans still need to be mirrored because we logically want the entrance directly on the street side. The garage should be placed directly at the boundary with the neighbor.
Site plan: red outline, 1400 sqm, blue border, green inner shape, roundabout on the right.
House floor plan: kitchen, living area, sleeping area, bathroom, guest room; double garage highlighted.
House floor plan with kitchen, kitchen island, dining table, child’s room, guest room, utility room, and double garage.
6 Jun 2022 10:49
Crax237 schrieb:
We are simply having trouble deciding where to best place which bungalow type/shape (L-shaped or angled bungalow).
Mark where you want the rooms to be. Make sketches. Again and again! Step away from the computer! And pick up a pencil!
Crax237 schrieb:
Intuitively, we would also build directly on the boundary with the neighbor
Which one?
Crax237 schrieb:
to enjoy the view of the open garden that is almost 42m (138 feet) long.
You can also enjoy the open view of the neighbor’s garden. Just saying. Many people, including you, focus too much on the neighbor instead of themselves. With the right planting, you can later play naked in your garden without any worries.
K a t j a6 Jun 2022 12:11
Are you sure about the dimensions? In my opinion, the proportions don’t match the picture.
Here is a start with a rough layout of the orientation, if it were my plot:
Site plan: Large square with purple outline, small square on the right, terrace on the left.
Road at the top of the plan.
Crax237
6 Jun 2022 12:26
@katja thanks for the drawing,
since the lower plot has already been surveyed, we were able to use the data exactly as is.
We hadn’t actually considered placing the house at the back before. 😱 We’ll need to think this over and redraw it on paper.
6 Jun 2022 12:27
If it were mine (which wouldn’t work for me either... with a length of 42 meters (137.8 feet), the width would be about 25 meters (82 feet)):
Site plan of a plot with house and a garage attached on the right within a red boundary.
Living/dining room and kitchen facing the terrace, with the utility room to the north. The bedroom is in the middle on the east side (the house and garage position would need to be adjusted because of a window), the child’s room in the southeast... office/guest room to the north or northwest...
K a t j a6 Jun 2022 12:45
Crax237 schrieb:
Since the lower plot has already been surveyed, we were able to directly use the data as is.
I don’t fully understand. Are the two supposed to be identical?
I would recommend clarifying this. If the figures don’t match the appearance of the survey map, then one of them must be incorrect.
Crax237 schrieb:
We hadn’t actually considered placing the house at the very end. 😱 We’ll need to think it over and redraw it on paper.
That is the most common option. However, for the driveway, you should check whether a minimum distance to the turning circle is required.
6 Jun 2022 12:48
... and here is my initial idea....
(only meant as a rough sketch, therefore no measurements or details)
Floor plan of a house with living/dining room, kitchen, bedroom, children’s room, bathroom, office, hallway, garage.
