ᐅ Build a retaining wall approximately 2.5 meters (about 8 feet) high.
Created on: 4 Aug 2020 12:46
Saarländer79
Saarländer79
4 Aug 2020 12:46
is it possible to build a retaining wall about 250cm (8 feet) high using concrete formwork blocks, so that the ground on top can be driven over by a car without the retaining wall breaking or shifting?
I was thinking of concrete formwork blocks measuring 50 x 25 x 17.5cm (20 x 10 x 7 inches)... of course reinforced with steel rebar and fully filled with concrete.
nordanney
4 Aug 2020 12:55
Phew, 250cm (98 inches) height and then the heavy load from backfilling and cars.
I would only do this with the involvement of a structural engineer.
Saarländer79
4 Aug 2020 13:01
Yes... there is about a 200cm (80 inches) difference in height... I want to set the bottom row of stones into the ground and then leave about 40cm (16 inches) as a wall above the terrain.
At the moment, there is a slope there, but I don’t like it. In the photo, you can see the slope quite clearly.
Construction crane lifts a white prefabricated wall over scaffolding in front of the shell; construction site with grass and trees.
HilfeHilfe
4 Aug 2020 13:34
I also believe that nothing can be done without a structural engineer...
A car weighs at least 1 ton (1,000 kilograms)
always going on and off there...
Steven
5 Aug 2020 11:36
Saarländer79 schrieb:
50 x 25 x 17.5cm (20 x 10 x 7 inches) planned...
Hello Saarländer,
17.5cm (7 inches) shuttering blocks leave you with about 9cm (3.5 inches) of concrete. Are you willing to take that risk?
I also wouldn’t install 30cm (12 inches) blocks without a structural engineer.
In that case, I would either fully form a 30cm (12 inches) wall or use L-shaped blocks designed for that purpose. However, L-shaped blocks are very expensive and you can’t install them yourself.
Steven
Saarländer79
5 Aug 2020 11:41
I have also considered using L-shaped concrete blocks, but such a wall can quickly cost around €25,000.
I need to consult a structural engineer to determine what support is needed and how to implement it.
