ᐅ Are ceiling heights over 3 meters (about 10 feet) uncomfortable? Experiences and insights
Created on: 20 Mar 2018 17:46
V
vgbau
vgbau20 Mar 2018 17:46
Hello everyone!
I would like to get some opinions on ceiling heights of 3 meters (10 feet) or more.
Do rooms with ceilings over 3 meters (10 feet) really feel as uncomfortable as large halls?
Is the energy demand significantly higher?
How tall should the windows be in such rooms?
My questions do not relate to apartments in older buildings!
Good luck
Knallkörper
20 Mar 2018 18:02
We lived in a house like this for several years. I didn’t find it uncomfortable. Only one room was unpleasant; it had just 10 square meters (about 107 square feet) of floor space, and we called it the silo. We used it as a dressing room. The windows with roller shutters reached to about 30 cm (12 inches) below the ceiling. Two large floor-to-ceiling window walls facing the garden were equipped with external venetian blinds. Both were good. In any case, high rooms definitely require large windows.
The energy demand must be higher. There is always a temperature difference over the room height. It is warmest near the ceiling, and with taller rooms, the temperature near the top must be even higher to achieve the desired approximately 22 degrees Celsius (72°F) at floor level. So, you have more wall and window surface area through which energy is lost, plus a slightly higher indoor temperature level. It will cost a bit more as a result.
11ant20 Mar 2018 18:34
High ceilings tend to make rooms feel narrower, which is more noticeable in smaller spaces. This might not matter much for a bathroom or pantry, but it becomes more apparent in a guest or home office room.
Windows need to increase in height proportionally; otherwise, the lintel casts too much "shadow" affecting the daylight that reaches the ceiling.
toxicmolotof
20 Mar 2018 20:13
It always depends on what you plan to do with it. Are you generally raising the ceiling by half a meter or more, or is it only at certain walls because, for example, the roof is a single-pitch roof or the living room is set lower to create more volume and impact?
In a child's room, I think 3.5 or 4 meters (11.5 or 13 feet) is great, as you can use wood and skilled craftsmanship to build 1-2 staggered levels, creating a play paradise. In the master bedroom, I would find it stylish only if I install a loft bed myself to make practical use of the space underneath. In the kitchen, it makes sense to stop where the 90cm (35 inches) wall cabinets end.
In the end... it’s totally a matter of personal taste and budget.
Baumfachmann
20 Mar 2018 21:09
I have an open roof with a ceiling height of 4.60 meters (15 feet) and 2.90 meters (9.5 feet) on the ground floor. I would do it the same way again.
11ant21 Mar 2018 00:30
Open roof soffits, however, belong to a completely different category in terms of proportional effect compared to simply raising flat ceilings higher.
