ᐅ Air Source Heat Pump and Chimney Located Side by Side
Created on: 15 Jan 2020 20:00
SimonBe3
SimonBe3
15 Jan 2020 20:00
Hello everyone.
Are there any issues with fine dust when the air source heat pump is installed on the roof and the chimney is located directly next to it?
Thank you.
Vicky Pedia15 Jan 2020 20:30
What type of chimney is this? Wood stove or other fuels? Are the exhaust gases directed through the main flue towards the fan?
SimonBe3
15 Jan 2020 21:03
Vicky Pedia schrieb:
What kind of chimney is this? Wood stove or other fuels? Are the exhaust gases directed by the main wind direction toward the fan?
Single-flue, room air-dependent chimney; 18cm diameter (7 inches); manufacturer: TONA; model TONAtec.
Wood stove – only wood as fuel.
The fan is located south of the chimney. Since the prevailing wind direction is rarely from the north, the exhaust gases are theoretically not carried toward the ventilation.
However, the distance between the fan and the chimney is approximately 1m (3 feet).
Vicky Pedia15 Jan 2020 21:11
My gut feeling is that this is not the ideal solution, but it will work. In the worst case, you might need to clean the fins/ribs from time to time. Try to achieve different heights on both sides as well. Basically, it should be fine. However, make sure to get a written confirmation from the plumber in case it turns out to be a bigger issue.
