Hello everyone, I recently got a Malm bed from IKEA and noticed that when turning or moving in bed, a squeaking noise occurs. The sound seems to come from the connection between the slatted frame and the bed frame. I have already checked if any screws are loose but didn’t find anything unusual. Does anyone have experience with this problem? What is the best way to eliminate the annoying squeaking? Is it advisable to lubricate with a specific product, or should other measures be taken? I appreciate any tips!
Squeaking in Malm beds is often caused by friction between wooden parts or at the screw joints. First, I recommend systematically checking all screws and connections and tightening them with the appropriate tool if necessary, as even slight looseness can cause such noises.
Next, it is useful to inspect the contact surfaces between the slatted frame and the bed frame. Dust or small foreign particles can accumulate there, leading to friction. Cleaning these areas with a dry cloth removes such debris.
To reduce squeaking, applying a dry lubricant is advisable, such as graphite powder or a specialized furniture wax that smooths wooden surfaces and reduces friction. Oily or greasy substances should be avoided, as they attract dust and can cause more noise over time.
Hello Roman61,
then you have a common problem that many furniture owners experience. One tip from me: also check if the slatted bed base is positioned exactly as intended. If it wobbles slightly, noises can occur when moving your body.
Sometimes it helps to attach small felt or foam strips – for example, at the contact points between the frame and the slats. This cushions the movement and can eliminate squeaking. You can find these strips at well-stocked hardware stores or online.
I also always say that cleaning is often underestimated.
Good luck with solving the issue, feel free to get in touch if you have any further questions!
gaubla schrieb:
Cleaning with a dry cloth removes these.
Good morning everyone,
I would like to take a closer look at this topic, as the construction principle of the Malm bed is crucial when it comes to squeaking. The bed consists of a wooden frame with a slatted bed base and often includes metal fittings. The squeaking usually occurs in the following areas:
1. Screw joints, which can still allow micro-movements even when tightened firmly – here I recommend carefully re-tightening the crosshead screws supplied by IKEA with a torque wrench to avoid damaging the material.
2. The wooden frame to slatted bed base support – here the wood moves slightly under changing loads caused by body movements, creating small friction. The buildup of abrasion increases the noise.
3. Metallic connecting elements, such as brackets, which can shift slightly against each other.
My approach for similar issues:
- Disassemble the slatted bed base,
- Clean all contact points (sawn surfaces, tongue profiles, etc.) with fine sandpaper (grit 220) to smooth rough spots or paint chips,
- Apply a dry, non-sticky lubricant (e.g., paraffin wax) on the support surfaces,
- If necessary, attach felt pads at contact points.
Before I forget: Sometimes it’s also worth replacing the slatted bed base if the old one is stiff or has cracks.
Has your bed been in use for several years, or is it relatively new? Did you perhaps assemble it differently from the instructions? Sometimes small differences here can cause the problem.
Hey Roman61 and all other squeak sufferers! 🙂
Squeaking is really the secret nightmare of any unplanned bed adventure, especially when you turn over in the middle of the night and the whole room sounds like a popcorn machine in action ;-).
So, what helps? I agree with the suggestions from gaubla and Katau – keep everything nice and clean and tighten the screws. Adding felt or rubber strips can work wonders to reduce the wood friction noise.
A little insider tip: If you don’t want to bother with sandpaper or expensive waxes, plain, unscented baby powder works well on the friction points – it absorbs the friction, stays dry, and doesn’t attract dirt. Just apply it carefully, and usually you won’t hear a thing afterward.
As I said, just give it a try and stay relaxed ;-)
