ᐅ Building a Retaining Wall in the Garden: Formwork Blocks or L-Shaped Blocks?
Created on: 24 Dec 2023 10:19
BiffBiff
In the garden, we need to build a retaining wall along 20 meters (65.6 feet). It will have a height of 1-1.2 meters (3.3-3.9 feet) and must hold back the soil on the property. It will only be supporting the garden. No road or building needs to be supported.
1) Which type of wall is more suitable? What are the advantages and disadvantages of a retaining wall with L-shaped blocks versus formwork blocks that are filled with concrete?
2) How should the foundation be prepared? Should it be gravel or a strip concrete foundation (how deep)?
3) What is the approximate cost per linear meter? Does anyone have relatively recent experience?
rasudiger25 Dec 2023 10:20
How should one imagine this? Does the neighbor then have a 3-meter (10 feet) high wall in their garden over a length of 20 meters (65 feet)? This should definitely be properly calculated; otherwise, the structure might slide off during the first heavy rain.
jens.knoedel
26 Dec 2023 09:43
I would be interested in seeing photos of the situation to get an idea of what a solution might look like.
Setting your blocks initially on the property boundary seems like a hopeless attempt to me. That can only be done once the neighbor has installed their retaining structure—ideally, you both do this together with a continuous 3-cell wall.
BiffBiff
26 Dec 2023 10:49
This might help to visualize it better.
Boundary between plot a and b: blue line, sloped terrain and stairs
jens.knoedel
26 Dec 2023 11:37
BiffBiff schrieb:
This might make it easier to visualize. [ATTACH alt="stuetzmauer-im-garten-bauen-schalungssteine-oder-l-steine-649854-1.jpg"]83442[/ATTACH]
Then it seems like only a "Together we can do this!" remains. Everything else will be a disaster.
P.S. You won’t be able to prevent the visual disaster at the neighbor’s either...
BiffBiff
26 Dec 2023 11:42
jens.knoedel schrieb:
Then it looks like it's just "Together we can do this!". Anything else will be a disaster.
P.S. You also can't prevent the visual disaster at the neighbor's...
How far away from the boundary would I need to stay to prevent any soil slipping? We plan to hire a structural engineer to address this question. To what extent is a structural engineer liable if slipping does occur? And how responsible is the neighbor?
X
xMisterDx
26 Dec 2023 12:17
The problem is that the neighbor has designed their wall to support their own property, if it was even engineered at all... Your support will transfer the force into their support—where else would it go. And the neighbor's support will not be designed to handle that.
