ᐅ "Smart" video doorbell and security cameras
Created on: 14 Feb 2022 09:38
Taitv789
Hello
we are currently planning our new semi-detached house
we have now reached the topic of video doorbells and security cameras
I have a few questions
Video doorbell:
which "smart" video doorbell can you recommend without monthly fees?
The video doorbell should have the following features:
When someone rings, there should be an audible signal inside the house (like a normal doorbell) and a notification should be sent to our smartphones
The video doorbell should also be seamlessly compatible with a smart door lock (e.g. Nuki) and it should work seamlessly together with the security cameras (all in one app)
At what height from the ground should the video doorbell be installed?
Which "smart" security cameras can you recommend? Should we choose the same manufacturer as the video doorbell?
Where should security cameras be installed?
Definitely one on the garage to cover the area next to the house.
Then only the entrance area would be left—do we still need an additional security camera at the entrance if we already have a video doorbell?
I have already looked and the big well-known brands like Ring (Amazon) and Nest (Google) all rely on cloud solutions with monthly subscriptions if you want all features
I have also seen Eufy (Anker) which works without cloud and monthly fees
What do you think of these brands or which ones would you recommend we check out?
Taitv789
15 Feb 2022 16:33
Thank you.
I don’t have an extreme need for security.
We have standard glass but enhanced security fittings to prevent prying open.
I had only heard about the LAN ports being used outdoors.
The cameras with lights and motion detectors are primarily intended as a deterrent.
We mainly want to install video cameras, a video doorbell, and smart home technology inside the house, including lighting, roller shutters, windows, and so on.
If Nuki is considered insecure, are there any good alternatives?
Mycraft15 Feb 2022 16:39
Taitv789 schrieb:
If Nuki is supposed to be poor in terms of security, are there any good alternatives?
Yes, GU-Secury, Fuhr Multitronic, and others.
Taitv789
15 Feb 2022 16:43
But those are not retrofit solutions, are they?
xxsonicxx15 Feb 2022 16:46
Mycraft schrieb:
@Taitv789
You should clarify your priorities first. On one hand, you're worried that someone might come to your house with a laptop or similar device, tamper with your doorbell, and then gain access to the house via the LAN port. On the other hand, you’re planning to use systems like Nuki… hmm, those were recently as vulnerable as an open door (not for the first time)… and attacks from outside are likely to increase in the future.
@xxsonicxx
Shelly devices aren’t very powerful. What do you have in mind for controlling the roller shutters?
For me, simply being able to open and close them… possibly with an intermediate controller or logic… would be more than enough.
I wouldn’t need to run through the whole house every time to close them, like I do now.
Mycraft15 Feb 2022 17:26
@xxsonicxx
So, no control system after all, just a simple central function and possibly additional positions. Yes, that works with Shelly devices.
@Taitv789
Locks can be retrofitted since they are usually standardized here. It’s just a question of how much you want to spend on the retrofit.
Taitv789
15 Feb 2022 19:28
I would first focus on the video doorbell and the security cameras.
I don’t quite understand this yet. Should I definitely use PoE for the doorbell and the security cameras?
