ᐅ Floor plan: 2 full stories, KfW 55 energy standard, 136 sqm, flat roof
Created on: 15 Dec 2021 23:19
Mansion
Hello dear building community!
We are planning our single-family home in an area with a development plan and would like to present our floor plan for your critical feedback. Thank you in advance for your time and comments – feel free to be straightforward!
Plot size: 530 sqm (5700 sq ft)
Slope: no
Site coverage ratio: 0.3
Floor area ratio: 0.6
Edge development: no
Number of parking spaces: 1
Number of floors: 2
Roof shape: flat roof, extensively greened
Architectural style: Bauhaus
Orientation: street on the south side
Maximum heights / limits: 7.50 m (24.6 ft) maximum height of attic flat roof; minor building parts may exceed building boundaries up to a maximum width of 5.0 m (16.4 ft) and depth of 1.5 m (4.9 ft) for windbreaks, staircases, entrance canopies, air source heat pumps, and balconies exceptionally permitted
Additional specifications:
- Base height limited to max. 0.50 m (1.6 ft)
- Garages and carports only allowed within the building envelope or the window for garages and parking spaces
- Driveway from the street may be max. 4 m (13.1 ft) wide
- Extensive or intensive green roofing
- Chimney not allowed
Homeowners’ Requirements
Architectural style, roof type, building type: Bauhaus, flat roof, solid construction, full stories, straight concrete staircase
Basement: no, number of floors: 2
Number of occupants, ages: 3 persons; 30 years, 30 years, 6 months
Ground floor space needs: open living-dining area, study, utility room, pantry, shower-toilet
Upper floor: master bedroom with walk-in closet, 2 children’s rooms, bathroom with tub and shower and 2 washbasins
Office: family use or home office? Home office / guest room
Number of overnight guests per year: 10-20
Open kitchen, cooking island: yes, possibly island or U-shape
Number of dining seats: 6
Fireplace: no
Music / stereo wall: no
Garage, carport: probably carport
Vegetable garden, greenhouse: maybe
Other wishes / special features / daily routine, also reasons why certain things should or should not be included
Who designed it:
- designer from a construction company
- based on the floor plan of a pitched roof house by a South German ecological prefabricated wood construction company
What do you particularly like? Why? Seating window and the staircase dividing the living-dining area, open ground floor, discreet upper floor
What do you dislike? Why? Storage space might be tight, utility room possibly too small
Price estimate according to architect/designer: not yet known
Personal budget limit for the house, including equipment: –
If you had to give up, on which details/extensions?
- could you give up: KFW 55 standard, T-solution in bathroom, kitchen island, if good reasons: possibly rotate the straight staircase 180 degrees to access it from the hallway
- cannot give up: in our opinion, the design does not reflect exaggerated demands already
Why has the design ended up like it is now? For example:
What makes it particularly good or bad in your eyes? The garden is important to us. In our opinion, the rectangular footprint is better suited than a square one to get the optimum out of the plot (sun on the west terrace). The floor-to-ceiling window on the south side in the kitchen.
The ground floor is nicely open and cozy and connects the garden and terrace with the house, while the upper floor offers enough privacy both inside and protection from outside views. We searched a long time for the optimal plot and want to use the land as the garden ideally as a retreat, with a possible swimming pond / pool later and a small vegetable garden.
Slope: no
Number of floors: 2
Fireplace: no
Who designed it:
Unfortunately, I can’t see the finished street elevation there either, but it will almost certainly be important for you. By the way, topography doesn’t come into existence only through its measurement, although Schrödinger and Heisenberg would probably find it amusing and touching that someone thinks so.
However, the locals are surprisingly mistaken here. I consider the most likely correct assumption to be that the contour lines represent half-meter intervals, meaning your building plot is about one and a half meters higher at the northern end than at the southern end – from my perspective, a clear reason not to hope you can ignore the terrain.The final development plan SCH718 is now available. With a bit of searching, you can find it in the city of Erfurt’s public information system. The street elevations from the technical development planning have been incorporated into the development plan (relevant here is 284.20 meters (931 feet)). The contour lines indicate 0.5 m (20 inches) differences. There are two contour lines passing through the building plot (unfortunately I cannot get a higher resolution).
Mansion schrieb:
The street elevations from the technical infrastructure planning were incorporated into the development plan (relevant here: 284.20m (928 feet)). The contour lines indicate differences of 0.5m (1.6 feet). Two contour lines pass through the building plot (unfortunately, I can't get a higher resolution). For me, it was enough to identify the two elevations – however, their position relative to the actual contour lines suggests that they are probably not finished floor heights. Therefore, they are not reliable for an informed guess about the finished floor heights. In the worst case, the area might be developed with above-ground utilities, but these heights could still be used as reference points for eave and ridge heights.
Hello everyone, it has been quiet with us for a while. Now the development work on our building site is gradually starting, and despite the challenging situation (interest rates, construction costs, material prices, etc.), we want to quickly decide on a construction company and request fixed-price offers based on the attached design. I look forward to your feedback 🙂
Mansion schrieb:
Hello everyone, it’s been quiet on our end for a while. Now the infrastructure work for our building site is gradually starting, and despite the turbulent situation (interest rates, construction costs, material prices, etc.), we want to decide on a construction company fairly quickly and obtain fixed-price quotes based on the attached design. I’m looking forward to your feedback 🙂 I haven’t read the previous posts, sorry for that. So, quickly: is there no basement? If not, where is the storage space?
The wardrobe is too small, the sink/vanity in the upstairs bathroom is far too small. The walk-in closet feels trapped—unfortunate when you have to pass by someone sleeping.
Access to the utility room is suboptimal, plus the space is very, very cramped. The kitchen could be improved ergonomically, the dining area is in a draft, and the mail carrier can look directly onto your plate...
I see many things here that could still be improved; I almost only like the cozy/separated living room.
As mentioned, I haven’t fully followed the thread, so maybe some points are less critical, but definitely not all.
Mansion schrieb:
I’m looking forward to your feedback.Without having checked in detail whether all suggestions have been carefully "addressed," I do get the impression that improvements have been made. But it’s your house, and it’s best if you double-check yourself whether you’ve completed all your homework ;-)https://www.instagram.com/11antgmxde/
