ᐅ Is it feasible for a layperson to install baseboards themselves?
Created on: 26 Aug 2020 21:36
kati1337
we have hired a painter for the entire house, including wallpapering and painting. I have now asked what he would charge for the baseboards but haven’t received a price yet.
Is it something a layperson could realistically do themselves? A miter box and a Japanese saw can be bought for about €70 (around $75). On Amazon, there are complete kits with baseboards and corner blocks available for just under €200 (about $215), although I haven’t calculated if the length would be enough. However, a friend mentioned that installing baseboards is much more difficult than it seems at first glance. Especially cutting for the corners would be a really tough job.
Do you have any experience with this? I’m not extremely perfectionistic, but it should look neat. Would you recommend letting a professional handle it, or is it something one can try doing oneself?
Bookstar
10 Jun 2021 22:56
annab377 schrieb:
How can you easily adjust it after 1.5 years without having to drill and anchor the clips again (a little deeper)? That would be a huge effort, wouldn’t it?
You simply slide the trim further down, as the clips allow a large range of movement. The clips are installed as close as possible to the floor.
annab377
11 Jun 2021 07:09
Bookstar schrieb:
You simply slide the strips further down because the clips allow a lot of play for movement. The clips are installed as close to the floor as possible.
Ah, okay, I didn't know that. But that is definitely a good thing 😎
