ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
haydee
7 May 2021 20:35
No, a cat's stomach is more resilient. Their nose is more sensitive.
micric3
13 May 2021 10:42
The week was very busy for us. Kitchen installation, telecommunications setup, and moving all happened on the same day. We are very satisfied, also thanks to the advice from this forum.
Modern kitchen with white cabinets, wooden countertops, cooking island, and window above the sink.
Grobmutant
13 May 2021 10:45
Looks good. 🙂
Was it complicated or expensive to extend the countertop into the window sill?
Myrna_Loy
13 May 2021 10:56
Nice layout and good division of space!
13 May 2021 10:59
micric3 schrieb:
kitchen setup
Why are the fronts of the island different? The shelving unit on the left side could have also been used very well there as a tall cabinet to repeat and balance the other widths.
micric3
13 May 2021 11:00
Rather a small additional cost. Significantly more expensive for engineered stone/granite countertops.
