ᐅ Letting Rainwater Infiltrate the Ground – A Cost-Effective Solution?
Created on: 28 Mar 2021 06:37
F
Fragenasker
F
Fragenasker
28 Mar 2021 06:37
I am looking for an affordable way to prevent our rainwater from flowing onto neighboring properties and to avoid unnecessary disputes with neighbors.
Regarding our specific situation:
Brandenburg, property size only 440 m2 (4736 sq ft), single-family house with a pitched roof. After subtracting sealed surfaces, about 250 m2 (2691 sq ft) of garden area remain, where the water should theoretically infiltrate. A rainwater cistern is not mandatory for us.
After some research, I have read that a cistern is only worthwhile for larger properties. Since we plan to have just some lawn and possibly a small flower bed on the property, but no additional trees, hedges, or shrubs, we consider a cistern unsuitable in our case.
We also do not want to create water basins due to the risk for children and potential mosquito breeding.
At least, we plan to build the driveway to the carport with a "bound gravel surface," which offers some water permeability.
Now to the question: Does anyone have similar property conditions or other practical, cost-effective ideas to prevent our rainwater from flowing onto neighboring properties during very rainy periods?
Joedreck
28 Mar 2021 07:58
Deep pit for placing concrete rings and installing the water connection. The rings have holes. Surround with geotextile fabric. Fill the pit with gravel.
motorradsilke
28 Mar 2021 09:14
And if you want an easier option, instead of concrete rings, simply use a green rain barrel.
Drill many small holes in it (use an 8mm or 10mm drill bit), surround it with coarse gravel (sourced from a gravel pit), and fill the inside with the same gravel. Place a landscaping fabric around the outer gravel to prevent soil from clogging it. Bury the whole setup about 30cm (12 inches) below ground level, put the barrel’s lid on top, and cover the outer gravel with another layer of landscaping fabric. Connect an extension from the downspout. Ideally, position it in a corner where cars won’t drive over it. It also works well under a lawn—walking on it is no problem—or under a flower bed if buried deep enough.
This has worked for us for many years.
dab_dab
28 Mar 2021 09:47
or just simply bury a few plastic soakaway tunnels:
costs for a small area are hardly more than a rainwater barrel, they weigh almost nothing, are designed for this purpose, and can even be driven over
caspar.1
28 Mar 2021 09:58
We installed a concrete soakaway chamber. The price including installation was 500 euros. We had the same issue of where to direct the rainwater. It drains away well, and the advantage is that if you ever need water for the lawn, you can simply put in a pump and drain it out.
F
Fragenasker
28 Mar 2021 10:11
caspar.1 schrieb:
We installed a concrete soakaway tank. Price including installation was 500 euros. We had the same problem with where to dispose of rainwater. It drains well, and the advantage is that if you ever need water for the lawn, you can simply put a pump in and pump it out 😉
Is this a kind of mini-cesspool, or what exactly is the difference?
Thanks in advance for the answers so far
