ᐅ Single-family house in Bauhaus style with flat roof, 2 full floors plus basement
Created on: 1 Mar 2021 15:41
Lheeman
Lheeman
1 Mar 2021 15:41
- No formal development plan. Construction governed by §34 Federal Building Code
- Plot size 700 sqm (7,535 sq ft)
Requirements from the Homeowners
Style: Bauhaus
Roof type: Flat roof
Building type: Single-family house
Basement: Yes
Floors: 2 full stories
Number of occupants, ages: Currently 2 (31 and 33 years old) + 1 child later
Space requirements on ground and upper floors: at least 180 sqm (1,938 sq ft) of living space
Office: Family use or home office? Both
Overnight guests per year: 0
Open or closed architectural style: open
Open kitchen, kitchen island: both
Number of dining seats: at least 6
Fireplace: yes
Music/stereo wall: home theater to be added later (Dolby Atmos)
Balcony, roof terrace: not required
Additional wishes / special features:
- Photovoltaic system with battery storage
- Basement to be convertible into home theater
- Increased ceiling height on ground floor. Usable height of 2.8 meters (2.55 m (8 ft 4 in) in upper floor)
- Ventilation system
- Ground floor designed for age-appropriate accessibility
- Access to terrace from dining area via fully folding sliding door to extend dining space into garden
- Plot borders a busy street to the south
Designed by:
- Architect
Cost estimate according to architect/planner:
€586,000 (approximately $635,000) without basement (€70,000 (approximately $76,000) for basement), land is extra
Personal budget limit for house including fittings:
€600,000 (approximately $650,000)
Preferred heating system:
Air-to-water heat pump with underfloor heating on all levels
If you have to give up, which details/features
- can you give up:
- basement
- open space with gallery
- cannot be compromised:
- increased ceiling height
Why did the design become the way it is?
We wanted a modern house that can still be used in old age or in case of disability. That’s why we planned a large office/guest room on the ground floor that can later be converted into a bedroom. For this reason, the ground floor bathroom is equipped with a walk-in shower. The exit to the terrace is designed to be level so that it can also be used with a wheelchair. Originally, the house was planned without a basement, so larger storage areas were created in the utility room and garage. The technical equipment will now be moved to the basement. We keep the storage areas upstairs despite having a basement so these remain accessible in old age. The basement might not be accessible in old age.
First, my wife and I are very happy with our architect’s design. Nevertheless, we would appreciate outside feedback. We are open to both positive and negative critiques as long as they are constructive. Maybe someone has useful suggestions for improvements.
Since we will have a fireplace and can obtain unlimited free firewood, maybe someone has ideas on where and how to store the wood efficiently.
Floor plan of a house with garden, terrace, and garage on the property
Upper floor plan of a house with bedroom, bathroom, walk-in closet, library
Basement floor plan: cellar 1, cellar 2, hallway, technical room, stairwell
Site plan: central house in garden, surrounding plots, north arrow.
Modern residential house sketch with large windows, trees, and green figures.
Modern architectural sketch of a house with flat roofs, trees, and playing people.
Modern cubic house with carport, sign HEEMANN 47b, green silhouettes of two persons and trees.
Ibdk141 Mar 2021 15:58
At first glance, it looks stylish. I’ll take a closer look later. So, just one question: which bathroom does the child use?
haydee
1 Mar 2021 16:00
If you can no longer manage the stairs as you get older, having a bathroom only downstairs won’t work for you.
There are stairlifts that make living on multiple levels possible. If that no longer helps, the question is whether you still want or can live in the house at all.
The budget is a bit tight; you are already over it.
Which bathroom does the child use?
Please provide all measurements again.
Wugler1978
1 Mar 2021 16:08
How much space do you have for maneuvering in front of the garage? We built ours the same way and needed 8.0 meters (26 feet) of space to be able to drive the car into the garage.
Lheeman
1 Mar 2021 16:17
Ibdk14 schrieb:
At first glance, it looks nice. I’ll take a second look later. So just one question: which bathroom will the child use?
The plan is for the child to use the parents’ bathroom during their early years and then to use the bathroom downstairs as a teenager. We initially considered a separate kids’ bathroom, but with only one planned child, we think three bathrooms are excessive.
haydee schrieb:
If you’re no longer able to climb stairs as you get older, the downstairs bathroom won’t be convenient for you.
There are stairlifts that can enable living on all levels. If those no longer help, the question is whether you’d still want or be able to live in the house at all.
The budget is a bit tight—you’re already over it.
Which bathroom will the child use?
Please post all the dimensions again.
Regarding the bathroom: see above.
Regarding the budget: we have a significant amount of equity and only set the budget to make sure the architect doesn’t become overly ambitious. The basement is generously provided by our in-laws as a gift, so it doesn’t incur any costs for us.
Bookstar
1 Mar 2021 16:35
Good aesthetics are naturally a matter of personal taste, but what I can say is this: the cost estimate from the architect might, at best, be accurate only for the cheapest area in Germany. If you’re heading further south, a significant additional amount will be needed. Garden and kitchen costs, etc., are extra as well, which is generally understood nowadays.
