ᐅ Reliable and Affordable Instant Turf Supplier
Created on: 9 Aug 2020 18:45
Z
Zaba12
I want to keep it simple and ask if anyone has already looked into the topic of turf in enough detail to recommend a good and affordable supplier or online shop! My landscaping contractor is going to shape the garden in the next few days. The landscaper suggests I should consider sowing the lawn in March. However, if I feel like it, I could also lay turf in early September, right?
Scout
10 Aug 2020 21:33
Tarnari schrieb:
But the irrigation really ran for hours every evening.
Especially at a facility in Egypt, that was truly impressive in a sustainable way.
I have honestly never walked barefoot on such grass before. It felt like a carpet.
Really amazing...
Barefoot? Oh my God—you do realize that the irrigation there (for example, at the golf course in Soma Bay) uses wastewater from the surrounding hotels? Only coarse solids are filtered out beforehand with rakes and tines...
Tarnari10 Aug 2020 21:52
Scout schrieb:
Barefoot? Oh my God – you do realize that the water used there (for example, near the golf course at Soma Bay) comes from the wastewater of the nearby hotels? Only the large solids are filtered out beforehand with rakes and tines...
Yes, barefoot. My feet are still intact, and I don’t have more calluses than before.
But that’s not really the point.
The fact is, this was the best lawn I have ever walked on in that hotel complex.
My question was: is micro-irrigation sufficient for this?
rick201810 Aug 2020 21:58
Usually not. In very large-scale systems, subsurface irrigation is used. On golf courses, huge lawn sprinklers are common. Within the facilities themselves, standard lawn sprinklers are used.
Micro-irrigation is mostly for small areas, such as a mini sprinkler with a 50cm (20 inches) range or, for example, drip emitters. Soaker hoses are basically drip pipes but less precise.
The reason a lawn looks so excellent is due to the type of grass, ample water, plenty of fertilizer, and regular maintenance.
Tarnari10 Aug 2020 22:02
rick2018 schrieb:
Usually not. In very extensive systems, subsurface irrigation is used. For golf courses, there are large sprinklers over the turf. Within the facilities themselves, standard sprinklers are used.
Micro-irrigation is mostly for small areas. For example, a mini-sprinkler with a 50cm (20 inch) range or drip emitters. Drip tubing is basically a drip pipe but less precise.
The reason a lawn grows so well/is so good is due to the type of grass, plenty of water, lots of fertilizer, and maintenance.
Seriously, that was really impressive. You could practically feel the lawn carrying you. I have never been on a golf course, but this is exactly how I imagine it.
Dense, firm yet simultaneously soft.
Like I said, like a carpet.
