ᐅ Suggestions for Improving a Single-Family House Floor Plan – Any Ideas?
Created on: 28 Oct 2018 15:19
nitta
After a long search for a suitable plot, we have finally found one. We are buying a turnkey house from the developer, who provided us with three floor plan options. Two of them were immediately dismissed by us, and the third one comes closest to our ideas, but we are still not fully convinced.
We like the layout of the upper floor and would like to keep it as it is.
However, the ground floor is causing us some headaches. Specifically, the area around the living room/dining room/kitchen. The current plan features a U-shaped kitchen, but we would prefer a solution with a kitchen island. For that, we would need more space. In our opinion, there is too much space in the living room to accommodate this. The distance from wall to wall is 4.50 meters (15 feet), which, in our view, makes the distance between the sofa and the TV too large. (Note: Our current living room measures 3.40 x 4.50 meters (11 x 15 feet), meaning the distance between sofa and TV is 3.40 meters (11 feet), which we consider optimal.)
We have therefore considered swapping the living room and kitchen. This would allow the kitchen with an island to fit, but the living room would then be too small because the width there is only 2.80 meters (9 feet), due to the wardrobe recess. We do not see another place for the wardrobe, as the hallway does not offer much space.
We are hoping for suggestions or ideas for improvement.
Here is our list of questions:
Development plan/restrictions
Plot size: approx. 430 sqm (4,630 sq ft)
Slope: no
Site coverage ratio: 0.35
Floor area ratio: -
Building envelope, building line and boundary: -
Edge development: -
Roof type: gable roof
Style: -
Orientation: S - SW
Maximum height/limits: -
Further specifications: -
Client requirements
Style, roof shape, building type: gable roof
Basement, floors: 2 full floors
Number and age of occupants: currently 2 (both mid-30s), in future 2 children
Space requirements on ground floor: living room, dining room, kitchen, guest WC, utility room, small office
Space requirements on upper floor: bedroom, walk-in closet, 2 children’s rooms, bathroom
Office usage: family use and home office
Guests per year staying overnight: approx. 3 nights
Open or closed layout: open
Traditional or modern design: modern
Number of dining seats: for 6 people (expandable to 8)
Fireplace: no
Music/speaker wall: no
Garage, carport: double carport
Additional wishes/special features/daily routine, also reasons for or against certain options: -
Planner: developer’s designer
What do you particularly like? And why?: upper floor layout considered optimal by us
What do you dislike? And why?: ground floor layout (living/dining/kitchen/wardrobe; see problem description above)
If you had to give up some details or expansions
-could give up: -
-could not give up: walk-in closet; open living/dining/kitchen area; house access from street side
Why is the design as it is now?: design by the planner based on our room needs and overall size
What do you consider its main strengths or weaknesses?: see problem description above
What is the most important/fundamental question about the floor plan in 130 characters?:
Does it make sense to swap living room and kitchen (see problem description above)? If yes, where else could the wardrobe be placed without making the hallway too narrow? Is the office size still adequate?
We would appreciate any suggestions or ideas for improvement from you.
Slope: no
Floor area ratio: -
Edge development: -
Style: -
Orientation: S - SW
Client requirements
Fireplace: no
-could give up: -
nitta schrieb:
We are buying a turnkey home from the developer, who provided us with three proposals for the floor plan. Two of them were immediately rejected by us, In such cases, I often suspect that if the rejected designs were also shown – of course with comments explaining why they were not considered suitable – it might help other participants follow the reasoning more closely. But this is just a general thought about such situations; in the specific case of this thread, the discussion seems to be developing well regardless.
Zaba12 schrieb:
We have a similar floor plan. Yes, funny that you replied right away – otherwise, I would have recommended your house for comparison.
otherwise I would have recommended your house for comparison. This would be this one: https://www.hausbau-forum.de/threads/Grundriss-für-11m-x-8-25m-ok.24781/
[a short while ago it was possible to edit a post for longer than 10 minutes – currently not again, so here is an added edit]
I’m actually curious how @nitta feels about your suggestions. Otherwise, the discussion won’t progress.
But then you’d need four showers I think you can also use the bathtub as an emergency shower. It’s worth reconsidering space-hungry solutions that would only be needed in rare situations.
So the shower space is actually needed for your equipment? Then I’d prefer comfortable laundry facilities instead.
One can tolerate many things, but it’s not necessary to accept everything when weighing up the options...
If money isn’t an issue, then add a whole meter (3 ft 3 in) right away.
It’s better to live more comfortably inside the house than constantly get frustrated by cramped spaces or squeezing around. The living room probably isn’t the problem, but the hallway, inconvenient access to the washing machine, no place to store laundry because dirty shoes are also kept in the same spot, and so on.
nitta schrieb:
We were thinking of it as an alternative option in case everyone wants to shower at the same time.
nitta schrieb:
We really need quite a bit of space in the utility room: equipment, washing machine, dryer, an additional freezer, vacuum cleaner, and possibly an energy storage system later. So it can’t really be any smaller...
nitta schrieb:
We would like to have an open staircase (for aesthetic reasons, even though it means losing storage space… everyone has their own ideas...)
nitta schrieb:
Also, we’re considering maybe making the house 25cm (10 inches) wider, so 8.74m (28 ft 8 in) instead of 8.49m (27 ft 10 in). This should be allowed according to the building permit/planning permission, but we still need to check. It will cost a bit more, but money shouldn’t be the limiting factor...
