ᐅ 30 cm Thick Exterior Wall – Compliant with the 2014 Energy Saving Regulation?
Created on: 1 Sep 2016 13:28
Silent010
Silent010
1 Sep 2016 13:28
Is it still possible nowadays to build an exterior wall with "only" 30cm (12 inches) thickness based on the mandatory energy-saving regulations?
Best regards.
Legurit
1 Sep 2016 14:25
Sure. Plaster carrier boards, stud framework with insulation wool, vapor barrier, installation layer, drywall.
Silent010
1 Sep 2016 14:57
Thank you for the response.
Sorry, I forgot to mention that the question relates to solid construction (for example, pumice stone, Poroton, limestone, aerated concrete...).
Legurit
1 Sep 2016 15:14
Difficult... possibly reinforced concrete with external thermal insulation composite system (ETICS).
Grym
1 Sep 2016 15:16
Poroton T8 is available from Wienerberger in a thickness of 30 cm (12 inches). This achieves a U-value of 0.26, just below the requirement of 0.28. Whether there are any structural issues – no idea.
By installing passive house windows and 30 cm (12 inches) of roof insulation, it might be possible to use a slightly less efficient block.
However, this is not advisable. Why not at least use 36.5 cm (14 inches) or 42.5 cm (17 inches) for monolithic masonry?
Legurit
1 Sep 2016 15:40
With plaster, it's more than 30 cm (12 inches)...
But Grym is right, why the requirement?
