ᐅ Wooden staircase, one step worn unevenly
Created on: 29 May 2015 22:28
sauder
sauder
29 May 2015 22:28
I am currently renovating an inherited house and have encountered a problem. The last wooden step leading to the upper floor is worn unevenly. On the left side, it is almost flush, about 3 mm (1/8 inch) lower than the upper floor covering, while on the right side it drops by up to 20 mm (3/4 inch). The staircase is stained mahogany. I just can’t find a suitable solution.
My latest idea was to attach a horizontal wooden strip in front of the step and use a leveling compound to even it out. Then I would fix a as thin as possible wooden board on the step and stain it to match. Is something like this feasible, and if so, which materials would you recommend?
Thank you.
Rudolf
lastdrop30 May 2015 08:35
The fact that it has worn down on only one side means that there is always a high load on that area. Your thin wooden board will soon be worn out again.
Can you not replace it completely? Use new solid wood instead?
Doc.Schnaggls
30 May 2015 14:14
I also believe that a repair as described above will not last long.
If in doubt, consult a staircase specialist who can manufacture a new step and install it immediately.
Regards,
Dirk
sauder
30 May 2015 21:00
Thanks, I will try to find someone.
