ᐅ Window frame ventilators – A good idea for uninsulated older buildings?
Created on: 23 Oct 2017 07:45
Specki
Good morning everyone,
I’m not sure if this is the right section for my topic, so please feel free to move it if necessary.
We bought a house built in 1964 in 2015. We have almost completely renovated it, including replacing the windows. The old windows were wooden double-glazed units, but the frame could be opened so you could get between the two panes of glass. I think you know what I mean. Obviously, they were far from airtight. Now we have installed airtight PVC double-glazed windows.
As expected, with these airtight windows in our uninsulated older building, we’ve been having some issues with moisture inside the house. By heating well and ventilating very thoroughly (at least 3 times a day), we’ve managed to get the humidity under control. The indoor relative humidity usually ranges between 50% and 65%. However, the windows still have some condensation on the lower part in the mornings. We successfully avoided mold last winter.
With the next winter approaching, I’m considering making some changes for the following reasons:
1. The frequent ventilation is annoying and time-consuming. Also, the rooms cool down a lot.
2. We are expecting our second child soon, and I doubt they will enjoy sitting in a 20°C (68°F) room when cold air suddenly keeps flowing in from outside.
I came across window frame ventilators (trickle vents).
What are your experiences with them?
I have already found out that they are designed to prevent drafts because they close at a certain airflow speed.
Some even have small “heat exchangers” integrated, so not all the heat is lost.
What I want to know:
Do these devices actually work? Will I really need to ventilate less to reduce moisture?
How much extra heating energy is lost?
My hope is to only have to ventilate well once a day (in the morning).
I don’t expect to have to heat significantly more since I would ventilate less.
I would appreciate your experiences and insights.
Specki
winnetou78
23 Oct 2017 10:51
We will also install a ventilation fan in the bathroom, but it is not strictly required for RegelAir.
Deliverer
23 Oct 2017 10:59
winnetou78 schrieb:
We will install a fan in the bathroom as well, but it is not strictly necessary with RegelAir.
Yes, but if you want a significant air exchange, it is recommended, right?
Joedreck
23 Oct 2017 11:02
Ventilation systems have the advantage of heat recovery. In terms of calculations, this is probably a zero-sum game. Both options have their pros and cons.
The "Bayernlüfter" units are said to be good. Whether they are really effective, I do not know.
Specki
25 Oct 2017 09:11
Thank you all for your responses.
I have now ordered four pieces for two windows and will test them out.
The cost is 37€, which is acceptable.
As I mentioned, I understand that this won't completely replace ventilation, but if it can help reduce the need for airing out, that would already be very good.
Regards,
Specki
Deliverer
25 Oct 2017 09:19
I would be surprised now – we have these devices in every window, plus three active fans. And that’s just enough so that you no longer need to open the windows for ventilation.
But I’m curious to see how it works in your older building and look forward to hearing from you soon! And feel free to share photos of the devices and their installation...
winnetou78
25 Oct 2017 09:26
Tell me more about your fans. Which ones and where are they installed?
