we are currently considering the height of the individual windows in our house. The ceiling on the ground floor is planned to be about 2.70m (8 ft 10 in) high. Standard windows usually start at around 90cm (35 inches) sill height and are about 125cm (49 inches) tall. With a 2.70m (8 ft 10 in) ceiling, there would still be more than half a meter of wall above the window. Should we simply plan for taller windows, or would that look odd from the outside? How tall are your (non-floor-to-ceiling) windows?
Kind regards
Sabine
Kind regards
Sabine
Sebastian7920 Jun 2016 19:16And once a single-leaf 1m (3.3 ft) door... forgot the "l"s...
Bauexperte20 Jun 2016 20:00Good evening Sabine,
In the example above, I would recommend switching to a height of 1.385m (4 ft 6 3/4 in), and for floor-to-ceiling window units, 2.26m (7 ft 5 in). These heights allow enough space for roller shutters on top and are visually pleasing, as they match the room height.
Regards, Bauexperte
Curly schrieb:It would need to be x-width by 1.26m (4 ft 2 in) height.
Curly schrieb:The standard module size for windows is 12.5cm (5 inches).
With a 2.70m (8 ft 10 in) high ceiling, there would still be over half a meter of wall above the window. Should the windows simply be made taller, or would that look odd from the outside?
Regards, Bauexperte
Bauexperte schrieb:
In the example above, I would recommend changing the height to 1.385 m (4 ft 6.9 in), and for the floor-to-ceiling window elements to 2.26 m (7 ft 5 in). These heights provide enough space for the roller shutters above the windows and are visually pleasing, as they match the room height.
Regards, BauexperteHow much space is needed above the window up to the ceiling if you want to install roller shutters?
Sabine
Bauexperte21 Jun 2016 07:24Hello Sabine,
About 30 cm (12 inches).
Regards, Bauexperte
Curly schrieb:
how much space is needed above the window up to the ceiling when installing roller shutters?
Regards, Bauexperte
