ᐅ Which wall cracks are problematic and which are not?
Created on: 9 Nov 2020 16:09
fraubauer
Good day.
I have various wall cracks in my newly built apartment (now 4 years old). Visually, they don’t look good.
Simply painting over them probably won’t help.
But which cracks are actually serious and which are just cosmetically unappealing?
For example, horizontal cracks next to windows and doors?
Or vertical cracks from the ceiling down the exterior walls (as seen from inside)?
It is difficult to estimate the depth and width. The length is visible.
Are there any general guidelines about this?
Thank you very much.
Alessandro
10 Nov 2020 10:02
then involve the property management and raise the topic of an expert surveyor at the next homeowners' meeting.
fraubauer
10 Nov 2020 10:16
Alessandro schrieb:
then involve the property management and bring up the issue of the certified expert at the next owners' meeting.
That’s what I thought as well.
apokolok
12 Nov 2020 11:10
Completely normal settlement cracks.
They will all disappear with the next coat of paint.
fraubauer
12 Nov 2020 11:41
Yes, that’s exactly the point. Are these all settlement cracks, or could they cause problems later on?
An expert can determine that. I am aware of that.
I have read here that cracks under 0.2mm (0.008 inches) are classified as hairline cracks, considered harmless if only in the plaster and not in the brickwork.
Cracks wider than 0.2mm (0.008 inches) should supposedly be examined more closely, as the brick might be damaged beneath.
Have I understood this correctly here in the forum?
This would help me when sorting the cracks.
apokolok
12 Nov 2020 12:04
These cracks can be found in every new building after some time. They are neither avoidable nor problematic. There is no need for an expert assessment in this case.
