ᐅ Which specialized tools are helpful for assembling IKEA Metod kitchen units?
Created on: 19 Feb 2020 08:37
Pubo42
I am currently planning the installation of my new IKEA Metod kitchen and wondering which special tools have really helped you during assembly. The instruction manual lists standard tools like a Phillips screwdriver and hammer, but I’ve heard there are even more useful tools that make the process more efficient or easier—such as special drill bits, angle guides, or clamping devices.
I am especially interested to know if buying such tools is worth it, which ones you would recommend, and at which assembly steps they are particularly helpful. Are there any tools that IKEA doesn’t provide but that fit very well with the Metod system?
Looking forward to your tips and experiences!
Using a cordless screwdriver with adjustable torque is not only convenient but also helps prevent chipboard from splitting.
Additionally, a drill guide/assembly aid set can be beneficial for making precise holes in difficult positions. Specifically for Metod, a small clamp combination is often useful to secure the elements and screw them together accurately.
Khalil schrieb:
I can highly recommend an angle gauge (or better, a combined angle and alignment tool) to ensure everything is perfectly square!Exactly! And a tip from me: Having a helping hand or a clamp makes aligning the carcasses much easier, especially when working alone. This way, you don't have to constantly hold the fronts in place. It saves both time and frustration 😊
RonJarrett schrieb:
Angle brackets are helpful when screwing in the shelves, as they ensure that the cabinet components remain perfectly square.Thanks for the tip! Are these angle brackets specialized tools by design, or are they just standard squares that I can find at a hardware store in the woodworking section? Do you think the more affordable standard versions are sufficient, or should they be more precise and sturdy for assembly? Also, what is the best way to use them during construction? I’d appreciate any advice on handling.
Angle brackets for assembly are usually standard metal brackets with a 90-degree angle, which should be sturdy and lie as flat as possible. A robust model commonly found at hardware stores is usually sufficient.
They are placed at the carcass corners to precisely check if everything is square when screwing parts together. They should be used as guides and spacers before fully tightening the screws. This prevents warping and ensures correct alignment.
Pubo42 schrieb:
Would appreciate any tips on handling.I’d like to add a folding plywood bracket angle to the discussion! They’re very flexible and lighter than metal, perfect if you quickly need something to align corners in between steps.
And yes, ever since I got a cordless drill with torque settings, I almost feel like an IKEA pro 😄
One more tip: A small magnetic tray for bits or screws can make assembly much smoother. You lose far fewer screws and have everything quickly at hand!
You also definitely need a sturdy work surface so the modules don’t wobble. This makes the work process much more relaxed!
