ᐅ Which pressure switch should be used to shut off the mechanical ventilation system with heat recovery?
Created on: 25 Aug 2016 19:48
Tommes78
Can someone tell me what electrical requirements I need to consider for a pressure switch to shut off the mechanical ventilation with heat recovery?
I tried to find information online but didn’t really succeed.
Does the pressure switch need to be installed near the chimney?
Does a hose need to be routed outside to measure the outside air pressure?
Does a cable need to be connected to the mechanical ventilation system to shut it off when the pressure switch is activated?
220 V (220 V) power supply near the pressure switch.
These are the points I would implement now. Can someone tell me if this is correct?
sven0924
23 Sep 2016 16:47
Hello, we were recommended the Leda LUC 2 by three different chimney specialists.
Payday
23 Sep 2016 18:17
sirhc schrieb:
For our new build with controlled residential ventilation, the issue is only the stove’s output relative to the cross-section of the flue pipe in the chimney. The stove installer must certify the correct setup of the stove, and the ventilation installer must confirm that the system extracts as much air as it supplies; then there is no need for a pressure monitor, a room-air-independent stove, or a DIBt approval.
What the local chimney inspector wants, no one will ever sign off on, and the chimney inspector is a real pain who keeps you hanging on false hope. My opinion on this is well known here. However, during construction, it makes sense to talk to the local chimney inspector and do exactly as he requests. Or simply install a pressure monitor, because that is the only method the inspector never objects to (it is theoretically the best solution).
The mentioned signatures won’t be issued on a permanent basis. The ventilation installer will definitely not sign off on this story. As always, nobody wants to take responsibility for anything. Of course, you could also switch off the ventilation system during the stove inspection ^^. In the end, it’s a lot of fuss over nothing. If the weather is unfavorable, even a pressure monitor won’t help at all. The whole issue basically exists to shut down the ventilation system when all fresh air inlets in the house are simultaneously closed, preventing new air from entering while air is still being extracted. This then creates a significant negative pressure.
