ᐅ Which Plot to Choose in a New Development Area? Pros and Cons
Created on: 3 Feb 2022 22:16
Melinaaa
Melinaaa
3 Feb 2022 22:16
We want to apply for three plots in the new development area but are unsure if we have chosen the right ones.
Our favorites so far are the numbered plots 1–3.
It is important to us that the living room and garden face the sun and that there is enough space to the neighbors so that we don’t overlook each other’s houses.
Do you think these are the right plots? Do you find having a second neighbor more advantageous or would a corner plot be better?
Is there anything else we should consider?
Thank you!
Site plan of a building plot with garden areas, trees, and building zones WA3 WA4
PhiIipp3 Feb 2022 22:44
Basically, these questions cannot be answered definitively. It always depends on many other factors. The local conditions cannot be determined from this plan. Which roads will have heavier traffic? What does the surrounding existing development look like? Is the plan oriented correctly to the north? Do the prices per square meter of the land differ?
What I want to emphasize:
You probably have a good understanding of the situation and can therefore make the best decision. Trust your gut feeling. The considerations you mentioned indicate that you already know what you are doing and what to pay attention to. Ultimately, you cannot arrive at the one correct solution mathematically if you cannot properly define and evaluate the variables.
The primary responsibility of the builder: make decisions!
Melinaaa
3 Feb 2022 22:51
Thank you for your time, we will do that 🙂
Nordlys
3 Feb 2022 23:20
WA 3.
In the case of WA 4, there is too much open space in the countryside, snow removal is mandatory, and there is constant foot and vehicle traffic passing by. WA 3 is sunny and relatively undisturbed.
11ant3 Feb 2022 23:53
I feel the same – the flat plan doesn’t show enough: no contour lines, no description of the differences between WA3 and WA4, ... "I can’t work like this" ;-)
altoderneu
4 Feb 2022 00:35
I don’t see anywhere on the plan whether there is a flood zone or a marshy depression ... nor where the highway is located ... nor where the best view of the Moselle Valley or the waste incineration plant can be found ...
I also don’t see contour lines, what is within a 500 m (500 yd) radius around it, or how the individual subplots were used before
--> not enough data to make an assessment
