ᐅ Which filling and adhesive materials are recommended for interior window sills made of stone or marble?
Created on: 11 Oct 2022 00:40
netzplan
White plastic window frame with green protective text; measuring tape lies on the floor.
Please see the attachment. Our new windows partially have two window sill strips at the bottom, each about 3cm (1 inch) thick. What material would you use to fill the area underneath? What would be suitable here?
netzplan
16 Oct 2022 21:31
motorradsilke schrieb:
The standard one can sometimes leave unpleasant stains on the surface.
Thanks again for the tip. Does it still bleed through up to 2cm (1 inch) from the bottom? (I was even considering whether to use lime-cement mortar because I expect there will be a lot applied)
motorradsilke
17 Oct 2022 16:20
netzplan schrieb:
Thanks again for the tip. Will it still bleed through with 2cm (1 inch) from the bottom? (I was even thinking about using lime-cement mortar because it might involve a lot of material.)
It can bleed through and then cause unsightly stains.
However, you can apply a layer of mortar or render at the bottom, then fill it with natural stone adhesive and spacer pads. I’m not sure if this is technically correct, but it works.
netzplan
17 Oct 2022 18:58
Great, thanks.
I was actually planning to order the window sills from the stonemason today. I wanted to look up examples of window sills with an overhang to get some ideas. Unfortunately, I came across the Helopal Linea with a shadow gap, which looks quite nice and is making my decision harder.
With standard window sills that have an overhang, you might consider re-plastering certain walls or doing similar repairs after 5-10 years. This wouldn’t be possible with flush-mounted window sills.
