ᐅ What does drywall construction include?
Created on: 15 Feb 2015 17:19
Lynyah
Hello!
We are currently in the planning phase of a house and have already spoken with several prefabricated house (PH) providers. We are trying to figure out where we can save costs. For example, drywall installation was estimated at €25,000. However, this is only the labor cost. The material will be supplied by the PH company. Now my questions are:
a) What does drywall installation include?
b) How many labor hours can I approximately expect for drywall installation in a house with about 164 m² (1,765 sq ft) of living space?
Thanks in advance
Lynyah
EveundGerd15 Feb 2015 19:49
That the quality depends on the manufacturer has been mentioned several times already.
Personally, I don’t find drywall installation that easy (you learn by trying :mad 🙂. With a labor cost of 25,000€ (about $27,000) I would stay away from it.
It sounds like a lot of work for a professional and a stressful challenge if you try it yourself.
In my opinion, warranty should also be a consideration here. There is no warranty with self-performed work.
MaxPower130
16 Feb 2015 06:43
Hello, regarding the scope of the drywall work, I can only say one thing: you’ve probably received a quote from the drywall contractor. Usually, it clearly lists the services included for 25,000€ (about 27,000 USD). If you’re not sure about it yourself, you should either post the quote or send it via private message. But it’s impossible to say generally what services you can expect without seeing the quote.
Bauexperte
16 Feb 2015 10:17
Lynyah schrieb:
a) what does drywall construction include?
Now I need to know which prefab house provider you contacted.
As a rule, drywall construction for a prefab house usually means that you only have the closed shell completed; all interior walls are also built using drywall systems. However, this raises the question of how connections for water and sewage are managed in this case.
Are you sure that the 25,000 euros are allocated "only" for drywall construction, or perhaps for more?
Best regards, Bauexperte
