ᐅ What types of damage occur most quickly to Billy due to improper installation?
Created on: 25 Jul 2024 08:14
Ellie63
I am currently looking into which damages occur most quickly on the Billy shelf when it is assembled incorrectly. I am particularly interested in damages that become visible relatively soon rather than only after several years. Specifically, I want to know if issues like warping of the shelves, tearing out of the dowel holes, or other structural weaknesses are especially critical in the beginning. Maybe overtightening or undertightening the screws also plays a role.
What experiences have you had with this? Are there common assembly mistakes that immediately cause damage, and if so, which ones? I look forward to your detailed insights so I can be sure to assemble it properly.
Filippo schrieb:
Do you always check the depth stop when pre-drilling holes for the anchors?Yes, absolutely essential. I always take the time to set up the drill with a depth stop to ensure the correct drilling depth. This protects not only the anchors but also the plywood from screws being driven in too deeply.
If the holes aren’t pre-drilled as specified, it’s absolutely necessary; otherwise, there is a high risk of damage and the panels tearing out.
Thank you all for the helpful tips! I will pay close attention especially to the advice about screw torque, mounting the back panel, and proper pre-drilling with a stop.
I am considering adding extra brackets for reinforcement on very large Billy-style shelving units to achieve greater stability. Do you have any experience or recommendations on this? Is it worth it, or is the original construction sufficient when assembled correctly?
