ᐅ What types of damage occur most quickly to Billy due to improper installation?
Created on: 25 Jul 2024 08:14
Ellie63
I am currently looking into which damages occur most quickly on the Billy shelf when it is assembled incorrectly. I am particularly interested in damages that become visible relatively soon rather than only after several years. Specifically, I want to know if issues like warping of the shelves, tearing out of the dowel holes, or other structural weaknesses are especially critical in the beginning. Maybe overtightening or undertightening the screws also plays a role.
What experiences have you had with this? Are there common assembly mistakes that immediately cause damage, and if so, which ones? I look forward to your detailed insights so I can be sure to assemble it properly.
An important aspect that is often underestimated is the correct alignment of the side walls and floors during assembly. Even small deviations can cause pressure points or lead to the floors sagging and bending over time.
Similarly, the back panel must be perfectly flat and fully secured. A crooked or loosely fixed back panel will quickly result in an unstable structure and subsequently cause permanent damage to the wood-based materials.
blapau schrieb:
make sure to plan and fully secure the back panelExactly! The back panel acts like a corset for the Billy. Without solid support, the shelf can start to warp unattractively even under the first load test. ?
I would also recommend gently tapping the back panel with a larger hammer if the nails don’t hold properly – applying too much force can quickly damage the wood panels.
KNUTGI schrieb:
Also, I would recommend gently tapping the back panel with a larger hammerThat’s a tip I hadn’t heard before. Is there a risk of applying too much pressure on the panels when doing this? Especially when I place the shelf unit on a smooth floor, I sometimes find it difficult to secure the back panel properly on all sides.
Marcellela25 Jul 2024 12:45If you don’t have enough support when hammering nails into the back panel, place a thin wooden strip under the hammer’s striking area. This will help distribute the force more evenly and prevent localized damage to the back panel.
SETHBLA schrieb:
The quickest way to cause problems is by overtightening the screwsI want to emphasize this very clearly. The chipboard is made of engineered wood with low fiber density, which means the material tears out easily.
A common mistake is to fully tighten the screws in one go instead of starting by carefully pre-driving them. This causes too much friction and heat, which further weakens the material.
Additionally, the drill holes should be as precise as possible. A hole that is too tight creates pressure on the wood when screwing in, while a hole that is too large is also problematic due to insufficient holding strength.
Do you always use a depth stop when pre-drilling the dowel holes to check the depth?
