ᐅ What are the legal requirements for a utility room housing an air-to-water heat pump?
Created on: 8 Jul 2019 09:00
micric3M
Mottenhausen8 Jul 2019 15:13Mycraft schrieb:
Ventilation must be provided.
This does not necessarily have to be a window.This is not meant to be provocative, but is that stated anywhere? It is still not too late for our utility room (without a window).
A controlled residential ventilation system with exhaust in the utility room is installed, and fresh air supply is provided via the door threshold. Formally, this should be fine, but in case of a power outage, for example, manual ventilation is not possible.
Mottenhausen9 Jul 2019 12:00Mycraft schrieb:
DIN 18 012 Um, unfortunately I can’t find a single word about the ventilation of a utility room (HAR) in DIN 18 012. Did I overlook it? WHERE EXACTLY is it stated?
Under
5.5.2 Utility Room
5.5.2.1 General
there are various structural requirements, but nothing about ventilation.
If, instead of a room, only a:
5.5.4 Utility Niche
is present, there are specifications regarding the width of the door gap as ventilation.
Under
5.4.2 Gas
it is also stated that the gas pipeline feed must be vented: so the underground conduit pipe must be vented with a T-junction, preferably just outside the building.
That’s all DIN 18012:2018-04 says on the topic of ventilation. This should be the latest version, as I can’t access a newer one via Perinorm.
