Hello forum, and thanks in advance for your tips!
My problem: I installed a new kitchen faucet (high-pressure model), but now no water is coming out. The background is that I originally just wanted to replace a faulty shower hose, which wouldn’t fit through the faucet’s opening. I called a plumber, who opened everything up and reinstalled it. After 2 hours, the hose was connected to the faucet, but suddenly several hoses started leaking. When he left, his “tip” was to replace the entire kitchen faucet with one that fits the shower hose better. This is odd because it wasn’t just the shower hose that leaked, but also the connection hoses to the shut-off valves.
I did that and installed the new faucet, but now no water is coming through. The main water valve is open. The shut-off valves don’t turn either left or right. However, I assume they didn’t just break overnight. The water was running fine before.
I suspect and hope that maybe I just need to turn something. Can you please help me? Does anyone have advice? Many thanks in advance!
__
Sink, instantaneous water heater (closed / high-pressure faucet)
Image 1: Connections with instantaneous water heater
Image 2: Overview
Image 3: Shut-off valves
Image 4: Shut-off valves. Red marking: When the plumber noticed the hoses were leaking, he tightened this nut. I have already opened it here, but the water still won’t flow.
__
Image 2: Overview
wrobel schrieb:
Hi
Are you actually turning the spindle of the angle valve?
Or just the handwheel?
OlliHi. Just the handwheel. I can’t reach the spindle (as long as the handwheel is still attached..?).
