ᐅ Wall-mounted toilet installed unevenly
Created on: 29 Nov 2015 17:43
V
Volkmann
Volkmann29 Nov 2015 17:43
the plumber installed the wall-hung toilet unevenly. When standing in front of it, the left side is clearly higher than the right side.
We will, of course, file a complaint. But my question is: Is it possible to fix this without major work? In other words, without having to remove tiles, etc.? As far as I know, these toilets are mounted on two threaded rods. So, the rods must not be level. And to reposition them, wouldn’t the entire wall need to be opened up again?
Mycraft29 Nov 2015 19:10
Actually, there isn’t much that can go wrong there... do you have a picture?
Volkmann29 Nov 2015 19:51
I don’t have one on hand right now. But the fact is: the toilet is installed crooked.
nordanney
29 Nov 2015 19:53
Volkmann schrieb:
As far as I know, these toilets are mounted onto two threaded rods. So, the rods probably don’t have to be perfectly level.
The holes in the toilets, through which the threaded rods pass, are noticeably larger than the rods themselves. So there is quite a bit of tolerance there.
Mycraft29 Nov 2015 20:30
That's why I asked for a photo... it is probably just screwed in crookedly.
wrobel29 Nov 2015 20:52
Hello
that’s how it is,
loosen the fasteners by 1 to 2 threads – align the toilet and then tighten again.
takes about 3 minutes
Olli
