lumpi195011 Sep 2014 23:59We have a rectangular wall box with a 125mm (5 inch) duct passing through it, as well as a second flap that simply allows air to flow either from outside to inside or vice versa. I’m wondering if this second flap is necessary. On the same floor (but in a different room), we have a fireplace and did not connect any tilt-window switches to the ventilation duct there. Is that why, or are there other reasons? I would like to switch from 125mm to 150mm (6 inch) because my kitchen specialist told me that with 125mm, the airflow maxes out at 500 m³/h (cubic meters per hour), and even if I use a hood with higher capacity, the air gets stagnant and nothing really works. What do you think about this statement?
125mm (5 inches) and 500m³/h (300 CFM) is really borderline.
The hood will work, but it will be somewhat noisier than with 150mm (6 inches).
We had a customer where, out of necessity, a 400m³/h (240 CFM) hood was connected to a 100mm (4 inches) duct.
At level 3, the hood was unusable. The backsplash behind the cooktop was soaking wet after just a few minutes. On level 2 it was better, but still not satisfactory.
If it is not too much trouble, you should upgrade to 150mm (6 inches).
Good luck
Good luck
