ᐅ Ventilation System CO₂ Levels [ppm] in Your Rooms
Created on: 19 Sep 2017 08:23
Tommes78
to all controlled residential ventilation system owners: Have you ever measured the CO₂ levels in ppm in your ventilated rooms out of curiosity?
According to information online, the values should be below 1000 ppm. About 400 ppm is the fresh outdoor air level. Normally, I have around 600 ppm – 700 ppm when no one is in the room. Of course, this value increases with the number of people present.
What I’ve noticed is that in our bedroom, the level rises above 1000 ppm during the night, which is not ideal. I originally thought that was exactly why I installed a controlled residential ventilation system – to always have fresh air.
So, I would be interested in comparison values from you, if you have any.
Maybe something is wrong with the system.
Mycraft10 Oct 2017 15:25
everything that is ventilated.
Bieber0815
10 Oct 2017 20:28
Yes, so everything, including the overflow areas (to avoid any possible misunderstanding).
Tommes78
10 Oct 2017 23:43
Okay, but that means the hallways must also be included since they serve as overflow areas, even if there are no supply or exhaust vents there. What about a connecting room (airlock) between the living area and the garage—would that also be counted as an overflow area, or is it excluded?
Bieber0815
11 Oct 2017 06:59
Is this connecting room within the thermal envelope? If so, then yes, that one as well. Maybe you could share your floor plan. Do you already have a ventilation concept?
