ᐅ Thinning the Back Panel of a Billy Shelf Unit – Why and How?
Created on: 19 Dec 2021 08:37
gregory41G
gregory4119 Dec 2021 08:37Hello everyone, I am currently working on thinning the back panel of my IKEA Billy bookshelf to reduce weight and improve stability when mounting it on the wall. My specific question is: Why does it make sense to thin the back panel of a Billy bookshelf, and what are the best methods to do this without compromising stability or affecting the appearance of the shelf? I am particularly interested in practical experiences, but also theoretical advice on materials and techniques. Thanks in advance!
FAVALERIE919 Dec 2021 09:03Thinning the back panel is worthwhile if you want to make the shelf lighter or need more space for cables behind the shelf. The best way to do this is by using a fine circular saw or a handsaw to carefully reduce the thickness of the back panel. It is important to keep the corners stable.
The back panel of the Billy shelf is usually a thin MDF board, primarily providing lateral stability. Thinning it out can be useful to reduce weight or to allow cable routing. However, this also reduces stability, so care should be taken not to weaken the back panel too much. It is advisable to only thin or cut out sections of the panel using a handsaw or a fine-toothed saw, rather than weakening the entire back panel. Alternatively, reinforcing strips can be added to maintain stability.
gregory4119 Dec 2021 11:19FAVALERIE9 schrieb:
Thinning the back panel makes sense if you want to make the shelf lighter or create more space for cables behind the shelf. Exactly, weight is a secondary concern for me; I want to create more room for wiring behind the shelf without compromising stability too much. gadalu schrieb:
Stability decreases if the back panel is reduced too much That’s true, I’m considering cutting openings in parts of the back panel and covering them with plexiglass-type elements. Has anyone had experience with this and can say whether it significantly affects stability?In my experience, the combination of cutouts and clear plexiglass inserts works quite well to create visibility and cable passages. It is important that the cutouts are not too large and that the edges are neatly finished to prevent fraying and cracking. By reinforcing the back panel in several places or supporting it with small battens, stability can be maintained even when it is thinned.
I find this quite an interesting topic because I faced similar challenges myself. It’s a challenge to make the shelf practical for technology and cables without it becoming unstable. Sometimes you feel uncertain because the shelf wasn’t originally designed for these kinds of modifications. In the end, I created small openings and sealed the back panel with thin but sturdy plastic to keep dust out. I also noticed that a bit more stability is always beneficial, for example by attaching small wooden strips from the inside.
