ᐅ Thickness of the floor coverings
Created on: 17 Mar 2016 12:05
U
Uwe82
I have some questions about floor coverings and gap sizes: We are planning to install laminate flooring of 10mm thickness (0.4 inches) plus 3mm (0.1 inches) impact sound insulation everywhere on the upper floor except for the bathroom. In the bathroom, we want to put tiles with a thickness of 10mm (0.4 inches). Will 3mm (0.1 inches) of tile adhesive be sufficient? (I haven’t been able to ask my tiler yet).
On the ground floor, we also have 10mm (0.4 inches) tiles with 3mm (0.1 inches) adhesive and 15mm (0.6 inches) hardwood flooring with impact sound insulation in the living room, so the screed there is 5mm (0.2 inches) lower than elsewhere.
Now the problem is the front door: If I calculate with a total tile height of 13mm (0.5 inches), I only have 7mm (0.3 inches) clearance to the bottom edge of the door. I might be able to gain a few millimeters by adjusting the door, but not much more. It would be possible to grind down the screed by another 5mm (0.2 inches), but I would prefer to avoid that.
18 Mar 2016 11:28
For 30 euros, you can already get a nice bamboo parquet, which is certainly more pleasant to the touch than any laminate, no matter how expensive it may be.
Saruss
18 Mar 2016 11:40
For 30 euros you can already get a nice bamboo parquet, certainly more pleasant to the touch than any laminate, no matter how expensive it is
Texture is overrated, at least my feet aren’t that picky. Otherwise, it’s also a matter of personal taste. Laminate offers significantly more and different designs, colors, etc. than parquet and similar flooring (only vinyl can compete with that).
In the children’s rooms, we chose it for the look and because it doesn’t have to last forever.
andimann18 Mar 2016 12:39
Hi,
we currently have laminate flooring in the house we rent, probably a lower price range.
Neige schrieb:
Laminate is not very child-friendly; it wears out pretty quickly. I would rather lean towards cork. In my opinion, low-end laminate isn’t really worth it, and cork is available at a reasonable price.
Cork has the advantage of being nicely elastic and sound-absorbing. The downside with dark cork is that it fades, and due to its elasticity, furniture marks are more noticeable. So, if you choose cork, go for a light color and use furniture glides, and everything will be fine.
So far, the laminate has even withstood the little one’s sliding around; I hope it lasts until November...
But I have a question about cork: Is it even possible to combine it with underfloor heating?
Kind regards,
Andreas
Bauexperte
18 Mar 2016 12:53
WildThing schrieb:
Well, I don’t think laminate flooring is as bad as Neige suggests.
I disagree, because essentially it is nothing more than resin-impregnated paper on a substrate. It’s inexpensive and quick to install in an apartment, but very sensitive to dropped household items or toys. Unfortunately, it’s also not repairable; laminate reacts very badly to water in particular.
I still remember the 1990s, when everyone had to cover their floors with laminate because it was quick and cheap to install—even cheap-looking. Every step echoed loudly on the laminate... terrible... maybe that’s also why I don’t like it. In any case, I wouldn’t want it in my home.
Nowadays there are better laminates in terms of quality, variety and noise level when walking, but they are still sensitive and therefore arguably unsuitable for children’s rooms. In my opinion, industrial laminate is a better option there. However, its price is so far removed from “cheap” that parquet flooring—with all its renovation possibilities—actually becomes a real bargain.
There are very good alternatives to laminate if you don’t want traditional wood or tile flooring—for example, cork or a nice carpet.
Best regards, Bauexperte
Uwe8218 Mar 2016 13:07
Carpet flooring is definitely not an option for us. We will take a look at cork as an alternative and order one or two samples. The choice of laminate was mainly based on financial reasons, and you really get annoyed with a more expensive floor when it gets damaged. Plus, you can replace it after a few years.
But as I said, we will now check out the alternatives.
Neige18 Mar 2016 13:14
Yes, you can check the information on HARO’s website.
