ᐅ Transparent / opaque patio roof
Created on: 19 May 2016 09:21
Payday
Now that it has been confirmed that we can attach a patio roof directly to the carport, the question remains whether to use transparent roofing sheets or the metal from the carport (with noise reduction, anti-condensation, etc.).
Advantages of transparent roofing sheets: bright, friendly atmosphere
Disadvantages of transparent roofing sheets: no sun protection
Advantages of metal roofing: sun protection during hot summers, easier to maintain since dirt is less visible
Disadvantages of metal roofing: the room behind is darker (which is not a big issue for us), noticeably cooler in autumn compared to transparent sheets (less heat gained through light)
When looking online, almost all options only show transparent roofing materials. That leaves me wondering how easy it is to keep such a roof clean. If stains remain after the first rain, then it’s probably not the right choice for me. What do you have? Any recommendations?
Umbau-Susi19 May 2016 12:00
We have polycarbonate panels as roofing on our balcony. They usually clean themselves quite well in rain or snow. The dirt is also less visible due to the pattern. We are satisfied with them, but they are somewhat expensive.
andimann19 May 2016 13:23
Hi,
no question, glass—and clear glass at that!
There’s nothing better than sitting under a glass roof on the terrace in autumn or spring, when the weather isn’t really ideal, protected from light drizzle, and comfortably grilling, reading, or just relaxing while all the neighbors have to stay cooped up inside.
Clear glass gives you the illusion of being outdoors while you can hear the rain on the roof.
Even summer thunderstorms during a barbecue lose all their fear factor.
My father installed such a canopy on our house back in the 1970s. At first, it featured wired glass, which was later replaced with clear, walkable laminated safety glass (VSG).
There was a large fir tree and a fruit tree nearby; we cleaned the panes once a year with a garden hose and a soft broom. That was sufficient. The time needed was about one hour for roughly 25 square meters (270 square feet).
Only two disadvantages of laminated safety glass:
Price—it’s not cheap.
Weight—the glass requires a corresponding substructure and, at panel sizes of about 3 meters (10 feet) long and 1 meter (3 feet) wide, is difficult to handle with typical household means. Our terrace had 4.5-meter-long (15 feet) glass panels; I still don’t know how they installed those without breaking the panes.
Andreas
Payday
19 May 2016 15:27
Thank you for your detailed response.
I am also leaning towards clear transparent glass, even though I was initially against it. In summer, we would simply hang fabric between the rafters under the roof for sun protection. My wife enjoys sewing, so that can be arranged.
Tempered laminated glass (VSG) is currently not affordable. However, the structural calculations should be sufficient since we are using the same thick timber as for the carport (which is made as one piece).
We just need to decide whether to go ahead with it now. The total cost, including installation, would be an additional 2000€ on top of the carport price.
Musketier19 May 2016 17:53
With €2000 (about $2200) you’re getting a good deal.
Since shortly after moving in, we’ve been considering a glass-aluminum canopy and awning. But that quickly adds up to €15,000 (around $16,500) or more. So far, we haven’t been able to justify that amount. The extra mortgage repayments seemed more appealing.
Payday
19 May 2016 19:30
It is also more cost-effective since it is integrated directly with the carport, and some costs only occur once (planning, setup/breakdown, travel, etc.; for example, gutters and waterproofing are only done once regardless of whether you waterproof 6 or 9 meters once everything is prepared). The roofing material used is not laminated safety glass (VSG) or anything similar.
For 6,000€ I can get a 6-meter (20 feet) wide awning with smartphone control from the company’s window specialist, including installation. Personally, I think that is too expensive, especially since awnings are susceptible to wind and not really suitable for rain protection. A cost of 2,000€ is reasonable and already significantly enhances the terrace.
19 May 2016 23:47
My mother gets sick just thinking about having to take down the fabrics again to wash them. And she was a decorator! ...
I have always thought about a glass roof when considering whether or not to have a solid roof at all. What puts me off about the otherwise stylish glass roof my parents have is the dirt on it. Well, the window cleaner only does it every six months because it is very expensive (risk to personal safety).
I would base the decision on the sun’s position—whether you would be willing to sit outside in the corner during a thunderstorm, or if you mainly need protection from rain or sun. A covered roof can actually be quite cozy.
What is the orientation of your plan? I still remember the drawing from the last topic... Which direction is at the top?
