BLÜMCHEN1239 Jan 2022 22:10Thank you all. I will take a look at the Osmo wax! I will sand more finely...
pagoni20209 Jan 2022 22:27That alone might not be enough. You change the sander at those spots, and the sanding pattern will be different. That difference will become visible on the oiled floor. Try responding to the follow-up questions...
BLÜMCHEN12310 Jan 2022 12:14The floor has dried.
However, it doesn’t look as bad in person as it does in the photos.
The issue was partly that when removing the pad, more oil tended to remain—mostly around the edges.
There are also stains that could be from food, drink, or oil. These have likely soaked into the wood.
I am planning to lightly sand over it and then apply Osmo decorative wax, aiming to lighten it a bit as well.
pagoni202011 Jan 2022 08:22I don’t think it’s that simple. Osmo is not a cure-all but just another supplier of finishes, although I generally like their products. Applying a different product on top of an existing one doesn’t seem like the best solution to me. Usually, sanding is the main cause of problems later on.
Can you explain how you sanded it or how you plan to do it now? For example, are you using a machine, and will the approach vary depending on the area?
In principle, I would recommend trying it out first on test pieces to see how it works.
If you want to use Osmo, there are various options like hardwax oils, decorative waxes, or stains...
BLÜMCHEN12311 Jan 2022 13:44I sanded with a large machine using 100-grit sandpaper.
Then I vacuumed and cleaned.
After that, I applied oil.
For the edges, I used a handheld sander.
Now I want to do the finishing work by hand...
