ᐅ Requirements for Fireplace/Stove Clearances
Created on: 10 Oct 2013 18:39
PhoenixDH
PhoenixDH
10 Oct 2013 18:39
I have a quick question because I haven’t been able to reach my local chimney specialist.
We are planning to install a stove inside, and next to it there will be a double wall where wood is intended to be stacked. The house has a bay window. In the corner between the bay window and the house wall, the chimney will extend upwards.
Now I have a question:
For walls or combustible materials, I believe the required clearance is 30cm (12 inches), correct? That would correspond to point 2 on the drawing.
But is there also a regulation regarding the clearance for point 1? There is also a rainwater pipe running along the wall.
So, what is the minimum distance the external chimney must maintain from the wall?
Please see the attached drawing.
Thank you.
Architektengrundriss mit Wänden, Linien und roten Markierungen im Plan
€uro
10 Oct 2013 19:43
PhoenixDH schrieb:
...I have a quick question because I can’t reach my responsible chimney sweep....
In that case, I would wait until they are available again, after all, the chimney sweep association holds a certain "authority," completely independent of what is posted here :-)
Milambar
10 Oct 2013 21:55
Distance from combustible parts = 1m (3.3 ft)
to non-combustible parts approximately 20 to 30cm (8 to 12 inches)
Milambar
10 Oct 2013 22:04
ps.. everything else will be specified by your home savings contract.. because, as mentioned above, it is the one that decides what you --must-- have
PhoenixDH
11 Oct 2013 05:29
Thank you for the information.
PhoenixDH
11 Oct 2013 05:30
And what about the external chimney, does anyone know about that?
