ᐅ Soundproofing – Differences in Interior Doors?
Created on: 2 Aug 2016 11:32
Basti2709
Hello dear forum members,
I would like to ask for your experiences regarding sound insulation in interior doors.
Last year, we had our own house built and also did a lot of the work ourselves. Among other things, my father (a longtime carpenter/joiner) and I installed the interior doors by ourselves. I have read a lot about home construction... but some topics, like the one mentioned above about interior doors, took a bit of a backseat. Honestly, we focused more on appearance and price than on function. In the end, we chose what we think are visually appealing interior doors with honeycomb core. After several months, however, I have realized the reason for the low price... in my opinion, the doors provide almost no sound insulation. Since we have a very open living area, a lot of noise carries into the upstairs rooms. I might be able to live with that if we didn’t have small children who are very light sleepers...
By now, I have come to the conclusion that “buying cheap means buying twice.” So at least I want to replace the doors on the upper floor. But how much improvement does such a replacement really bring? Since the doors need to fit the existing frame, the selection is limited. I have now found doors with a tubular chipboard core... does that already offer a meaningful improvement? Or do you need a solid core door?
With the current interior doors, I cannot notice much difference between closed and open. Does anyone have experience with how much sound insulation different door cores provide? For example:
- Honeycomb core / 20 dB
- Tubular chipboard frame / 40 dB
- Tubular core / 50 dB
- Solid core / 55 dB
The goal is to figure out whether it makes sense to choose a certain core type. If the difference between solid core and tubular chipboard frame is small, then tubular chipboard is enough for me... if only the solid core really improves sound insulation and the difference between tubular core and honeycomb core is barely noticeable, then I can save myself the tubular chipboard option...
What kind of doors do you have and how satisfied are you with the sound insulation?
Basti2709
nordanney
20 Sep 2018 13:48
mertmk3 schrieb:
Standard doors would then be hollow core (no stringer)
Why not solid wood from the carpenter? The price difference is minimal (if any).
Bookstar
20 Sep 2018 14:08
Solid construction is not recommended. The doors tend to be quite heavy. In terms of cost, you’re looking at about a thousand per door.
nordanney
20 Sep 2018 14:36
Bookstar schrieb:
You’re looking at about a thousand each door in terms of cost.
Including the frame at around 500€ (approximately $550) for spruce, painted white as an entry-level option. "Better" wood will be somewhat more expensive, but that’s more a matter of personal taste.
In my previous house, I had solid wood doors (they weren’t harder to operate, thanks to Tectus concealed hinges), and now in my apartment, I have hollow core doors.
mertmk3
20 Sep 2018 16:01
My main concern is the floor sealing. Do you think an RSPK door with Schallex floor gasket is sufficient?
Bookstar
20 Sep 2018 18:06
Phew, you definitely won’t get a carpenter-made door in the South for 500 euros.
nordanney
20 Sep 2018 23:33
Then just order it online and install it yourself. You can even have two fairly clumsy hands and it will still work.
