ᐅ Size of the drilling / milling in 20mm porcelain stoneware
Created on: 23 May 2018 06:44
Bentovic
Bentovic
23 May 2018 06:44
Yesterday, I started installing 20mm (0.8 inches) porcelain tiles on the terrace. Now I still have the drain pipe, which I would preferably like to install using a core drill. A two-piece tile looks unattractive.
Are there suitable hole saws, or can this be done with a router bit? Core drills don’t have a centering tip, so you would need to build a fixture to mount the machine with anchors and clamp the tile securely.
Stephan
kkk272729
23 May 2018 07:34
This is done using a diamond core drill bit for the angle grinder, freehand.
Bentovic
25 May 2018 21:48
It worked quite well with a core drill and a suitable drilling template made of wood.
