Hi, from the beginning we actually wanted to install a recessed shelf in our shower (see picture).
Unfortunately, we forgot this in all the stress.
The interior plaster is already applied, as well as the screed.
Is it still possible to create a niche in the side wall facing the storage room?
It is a non-load-bearing Ytong wall (11.5cm (4.5 inches) block) and with the plaster we have a 14cm (5.5 inches) thick wall.
We were thinking maybe about 70cm (28 inches) long, 30cm (12 inches) high (one tile height), and about 8-9cm (3-3.5 inches) deep.
Would that be possible? Especially since the plaster is already on? And without having to break through the whole wall?
Bau-Schmidt29 Oct 2017 09:47305er schrieb:
And why? Think about it.Your profile suggests you have some craftsmanship skills.
Please be a bit more detailed.
305er schrieb:
It’s a non-load-bearing Ytong wall (11.5cm (4.5 inches) block) with plaster, so we have a 14cm (5.5 inches) thick wall. That leaves 2.5cm (1 inch) block and 3cm (1.2 inches) plaster. That won’t work without cracks in the plaster.305er schrieb:
The idea was maybe about 70cm (28 inches) long, 30cm (12 inches) high (one tile height), and about 8–9cm (3–3.5 inches) deep. Not without a lintel.305er schrieb:
Would that be possible? No.305er schrieb:
Especially since the plaster is already on? Not without damaging the plaster.305er schrieb:
And without knocking through the wall? That will probably happen.W
winnetou7829 Oct 2017 20:14Why not limit the depth to 5–6, then it will fit with a lintel and a 6cm (2.4 inch) Ytong block at the back.
