ᐅ Securing KALLAX with anti-slip pads – are there suitable options available?
Created on: 17 Jan 2020 08:17
keplo
I have a KALLAX shelf unit from IKEA and would like to secure it better against slipping, especially on smooth floors like laminate or tile. My main concern is preventing it from tipping over, as the unit is quite tall and may occasionally hold some weight.
So my question to the community is: Are there any specific anti-slip pads that fit well under KALLAX shelves? Important factors for me are size, adhesive strength, and whether they can be removed cleanly without leaving residue.
So far, I have only found general anti-slip pads online, none specifically sized for KALLAX or that are larger or custom-fit. Are there any recommended products or tips for secure attachment?
Thanks for your detailed opinions and experiences!
Ianlau schrieb:
Metal angle bracket inside, at the top of the back of the KALLAXThat’s exactly how I did it! 😉 It looks almost invisible and gives a sense of security.
As an additional tip: If you don’t want to drill, some manufacturers offer adhesive angle brackets. However, you should be cautious depending on the weight and load.
The silicone pads themselves are great for protecting the floor and preventing slipping. But I wouldn’t rely on them alone if children or heavy loads are involved.
Good luck with your project!
Thank you all for the helpful advice and tips!
After some research, I have now ordered 4mm (0.16 inches) thick, self-adhesive silicone pads made of TPE and will install them tomorrow. At the same time, I am looking for suitable metal brackets to attach to the wall, ideally at the top inside of the back of the shelf.
With the information on cleaning, material properties, and installation, I feel well prepared.
Once everything is installed, I will gladly provide an update on the function and durability.
Thanks for the great community here :-)
