ᐅ Should the joint between the ceiling drywall and the wall be sealed?
Created on: 11 May 2021 20:47
MathodoHello,
My name is Markus, I am 47 years old and work as a locksmith.
We have recently built a new house. We are doing the painting work ourselves. Unfortunately, I filled the joint between the drywall and the plastered wall with filler, which caused significant cracking.
I have now removed the filler and would like to ask for advice on the proper professional method to proceed. The joint is currently 3 to 6 mm (0.1 to 0.2 inches) wide. Thank you in advance for your help.
Regards, Markus
Regards, Markus
nordanney11 May 2021 21:01Buy angled corner tape and apply joint compound.
I wrote something earlier but was warned for it, no idea why. Allegedly off-topic and without added value, even though it was advice specifically for the original poster. I’ll try again with a rephrased version.
The joint cracked because the plaster behaves differently than the concrete.
So either use a flexible joint (silicone or acrylic), but this is a maintenance joint and needs to be renewed regularly. Or create a reveal joint (keep the joint clean and consistently sized everywhere). Or attach ceiling moldings (on one side).
nordanney12 May 2021 18:54Mathodo schrieb:
A friend advised me against using Kurt joint tape; I’ve seen the ceiling-to-wall connection myself. The tape detaches from the plaster and/or tears.
Does anyone have another suggestion? Not applied correctly. If properly filled and finished, it won’t tear. I have over 40 meters (130 feet) installed in my place without any issues. You won’t get a neater finish visually.
