ᐅ The screed is laid – should tiles be installed in the utility room due to the heat pump?
Created on: 21 Mar 2020 12:22
Andre77
Andre77
21 Mar 2020 12:22
Hey,
the screed has been in place for 1.5 weeks. If nothing changes, the heat pump is scheduled to be installed in week 15. Tiles should be installed under the heat pump as well. My site manager mentioned that you could lay tiles there using a vapor-permeable adhesive. What do you think?
And if so, should the tiling be done only in the area of the heat pump or also in the utility room and the adjacent storage room?
Thanks!
By the way, what tile sizes do you usually use in the utility room? Maybe some pictures as well?
Domski
21 Mar 2020 12:43
Use an s2 adhesive, which is basically approved for use right after curing (usually specified from day 3 after screed application in the technical data sheet) and apply it initially only to the absolutely necessary area. Is it cement screed?
seat8821 Mar 2020 13:03
Wet-on-wet works. And after 1.5 weeks, it is still considered wet.
Andre77
21 Mar 2020 13:04
Domski schrieb:
Use an S2 adhesive, which is basically approved for use once cured (usually indicated from day 3 after screed installation in the datasheet), and initially apply it only to the absolutely necessary area. Is it cement screed?
Yes, it is cement screed.
Andre77
21 Mar 2020 13:07
@seat88
How long is this considered wet?
The reason is that I want to buy tiles today before the home improvement stores close, and the tiler—if allowed to continue working—will tile as long as he has time...
seat8821 Mar 2020 13:13
I’m not a tiler either, but ours estimated about 2 weeks.
