ᐅ Room Height: Meaning of the Term "m.i.L." – Does Anyone Know This?
Created on: 27 Mar 2018 23:02
AnNaHF79
AnNaHF79
27 Mar 2018 23:02
our quote states the following:
Ground floor height:
The ground floor height is set at h=2.56 meters (8 feet 5 inches) clear height (raw dimension, increased due to underfloor heating).
Note: The ground floor height is measured from the top edge of the basement ceiling to the bottom edge of the ceiling above the ground floor.
Does "clear height" refer to the internal height, correct?
What ceiling height can we expect when everything is finished?
Thank you.
toxicmolotof
27 Mar 2018 23:35
Answer a)
Unfortunately, my crystal ball is broken.
Answer b)
It probably depends on the floor structure.
Answer c)
It depends on the thickness of the ceiling plaster.
Answer d)
A combination of a, b, and c.
If I had to guess: around 2.40m (7 ft 10 in)
toxicmolotof
27 Mar 2018 23:48
Note: The clear height should actually be the distance between the underside of the ceiling plaster and the top of the finished floor covering, but the issue with the underfloor heating makes me think otherwise.
11ant28 Mar 2018 01:07
toxicmolotow schrieb:
Actually, the clear height should represent the distance between the bottom edge of the ceiling plaster and the top edge of the finished floor covering,
I agree with that, but the term "rough dimension" makes me suspicious, as it seems contradictory to a finished dimension. In my view, the underfloor heating only explains why it is 2.56 m (instead of the usual 2.50 m (8 ft 2 in) perhaps).
AnNaHF79
21 Apr 2018 16:15
So, the answer was indeed 2.56 m (8 feet 5 inches) in rough measurement and 2.40 m (7 feet 10 inches) in finished measurement; we now had to pay extra to increase it to 2.60 m (8 feet 6 inches) in finished measurement.
