ᐅ Repairing Damage in Your Sink Yourself
Created on: 21 Nov 2024 23:46
Faltenträger
Faltenträger
21 Nov 2024 23:46
Has anyone had experience with ceramic repair kits (or whatever they are called) for ceramic sinks? Can you recommend one that is not too expensive and can cover small chips and/or possibly a crack?
I’m asking regarding a rental apartment (yes, here in this forum! :-)) shortly before moving out. The liability insurance would even cover the deposit... but if it can be repaired effectively, that would be best for everyone involved.
22 Nov 2024 00:58
Faltenträger schrieb:
to cover up a crack
To me, that is fraudulent misrepresentation. What value are we talking about for a washbasin in a rental apartment?
nordanney
22 Nov 2024 09:18
Has anyone had experience with ceramic repair kits (or whatever they are called) for ceramic washbasins? Can you recommend one that is not too expensive and can cover small chips and/or possibly a crack?
I’m asking because of a rental flat (yes, in this forum! :-)) shortly before moving out. The liability insurance would even cover the deposit... but if it can be reasonably repaired, that would be best for everyone.
First: a photo of the situation
Second: chips (depending on their size) are quite common signs of wear and tear and are not your responsibility to repair. The landlord collects rent and cannot use the deposit for that accordingly.
Buchsbaum066
22 Nov 2024 09:46
nordanney schrieb:
Secondly: minor defects (depending on the size) are quite common signs of wear and do not need to be repaired by you.
Is a crack in the washbasin a common sign of wear? No!
Chips or surface damage are also not typical signs of wear for sanitary ceramics.
In that case, the washbasin must be replaced at the tenant’s expense or covered by their insurance.
Limescale or rust stains are more typical signs of wear. Mechanical damage, for example caused by glass cream jars falling, is the tenant’s responsibility.
Arauki11
22 Nov 2024 10:38
A washbasin like this in a “standard” rental apartment costs very little. First, ask how much it would cost you. Repairing it seems more like a hassle and also costs money. Just replace it and be done.
Jesse Custer
22 Nov 2024 11:56
I once tried something like this in our bathroom many years ago. Conclusion: don’t do it.
- You NEVER get the exact color match.
- The base always shows through.
Although I was able to hide a small chip this way, you can still see the color difference on close inspection...
