ᐅ Painting a Billy Bookcase After Assembly – Best Approach?
Created on: 10 Mar 2024 08:12
traabiga42
Hello everyone, I am planning to repaint my already assembled Billy shelf to give it a more modern look. I want to achieve a smooth, durable finish that lasts a long time – not just a simple fresh coat, but one that is resistant to scratches and moisture. My question is: what are the best steps to follow for such a project? Specifically, I am interested in how to properly prepare the shelf (sanding, cleaning), whether I need to completely remove the original finish of the Billy shelf, and which type of paint is recommended (e.g., acrylic paint, polyurethane paint, spray paint). Also, do I need to apply a primer before painting, and if so, which one? Are there any experiences regarding painting directly on particleboard, or is a special intermediate layer necessary? I appreciate any detailed advice!
ju_ren
11 Mar 2024 09:12
Regarding room temperature: I have also painted at below 15°C (59°F), which caused blistering. So it’s better to avoid that.
The primer I used was from "Clou." It worked well and dries in about 30-40 minutes.
Sand lightly with 320 grit sandpaper after priming, then apply the paint.
Maria35
12 Mar 2024 12:55
In addition, humidity is an important factor: Excessive humidity (above 65%) can negatively affect the drying and curing of the paint. For the best results, room temperature and humidity should be monitored.
Another tip for sanding: Damaged edges and areas with chipped coating should be repaired beforehand using wood filler or repair compound to achieve a clean finish.
Solvent rise in overly thick layers can be avoided by applying the paint in thin, multiple coats.
PeoDaniel
12 Mar 2024 15:08
Maria35 schrieb:
Humidity above 65% is bad for drying
Absolutely, these environmental conditions also affect professional painters. Ventilation is important, but avoid drafts.
Summary for you:
- Sand melamine surface (P220)
- Prime with adhesion primer (e.g., Clou)
- After drying, sand lightly between coats (P320)
- Apply 2-3 coats of polyurethane or acrylic paint
- Optional clear coat for protection
- Dry at 18-22°C (64-72°F) and moderate humidity
This should help your Billy shelf hold up well with its new look. Good luck!
