ᐅ Question about room size for heating equipment
Created on: 1 Sep 2011 13:28
emer
emer1 Sep 2011 13:28
We now have the architect’s plan. The room marked as the utility room is shaped in a way that doesn’t work well for us.
It measures 5.7 sq.m. (1.50m by 3.80m / 5 ft by 12 ft approx.).
This is a bit too narrow for a washing machine and dryer. We would like to use a different room as the utility room.
So far, no problem.
Now, the heating system is supposed to go in this room.
Dimensions (WxDxH): 70cm x 65cm x 182cm (27.5 inches x 25.5 inches x 71.5 inches) (the intake unit is outside).
And the ventilation system (supply and exhaust air).
Dimensions (WxDxH): 35cm x 60cm x 65cm (14 inches x 24 inches x 25.5 inches).
I have rounded the numbers somewhat.
Does anyone have experience with fitting these devices in a room? Considering that there will also be cables, pipes, and everything else that needs to be connected, this is not like placing a shelf directly against a wall.
How many centimeters (inches) of clearance should I allow from the wall to make everything fit?
Is the room large enough?
How much total floor space will the systems take up?
Thank you very much.
€uro
1 Sep 2011 14:52
emer schrieb:
....Now the heating system is supposed to go into this room. Dimensions: (WxDxH) 70cm x 65cm x 182cm (the intake device is located outside)
This will probably be an air-source heat pump with a split unit and an integrated hot water storage tank inside! Is this even suitable? Heating load, room heat load, radiators, hydraulics?
emer schrieb:
...How many square meters will the systems occupy in total?
I think there is an architect getting paid for this!
This looks like quite a botched system! My condolences!
€uro
2 Sep 2011 13:58
emer schrieb:
The only specific detail I know about the system so far is that it includes a 300-liter (79 gallon) domestic water tank. The system is supposed to heat 170 m² (1,830 ft²) of usable living area with a ceiling height of 2.50 m (8.2 ft). The KfW rating is approximately 60 to 65.
As already mentioned, my condolences!
emer2 Sep 2011 14:34
Really very helpful and qualified statement.
Häuslebauer40
2 Sep 2011 18:15
Bauexperte schrieb:
Two years ago, we designed a slightly smaller utility room at a customer's request, providing space for a dryer and washing machine; however, nothing more can be accommodated.
Oops, then I'm curious. Mine is planned to be that small as well. According to the plan, there’s even room for a freezer combo, and all the doors can still open—at least, according to the plan...
Bauexperte
3 Sep 2011 01:34
emer schrieb:
Bauexperte, do you think that will fit? How much floor space do such systems with connections usually take up? I haven’t seen such an installation fully installed yet.
I don’t know which system you are referring to – there are combined units ranging from to – so I can’t really tell you if it would fit.
The utility room I mentioned measures approximately 2.70 x 2.47 x 2.60 m (8.9 x 8.1 x 8.5 ft), with 3 doors leading off it, so only one completely free wall is available. On this wall the house connection (HC) is installed, along with the meter cabinet and the sub-distribution for the underfloor heating of the ground floor. To the left of this wall, with it at your back, is the door to the kitchen, and on the remaining wall section are the washing machine and dryer. Opposite the wall without doors, another door leads to the attached garage, and to the right of this doorless wall are the domestic hot water storage tank and the indoor unit of the air-to-water heat pump, with enough space before a further door at the end of the wall leads into the entrance area.
emer schrieb:
The only thing I know in more detail about the system is that it includes a 300 liter (79 gallon) domestic hot water tank. The system is supposed to provide heating for 170 m² (1830 sq ft) of usable floor area, with a ceiling height of 2.50 m (8.2 ft). The KFW energy standard is about 60–65.
Then it is high time you get detailed information about the system from the seller or general contractor; you wouldn’t be the first to have to redesign parts of the work later because it was overlooked to discuss the sizing of the energy supply.
Kind regards
