Surprise: Cold water setting changed → unintentionally filled flower bucket with hot water
As if by magic, the temperature selector shifts from COLD to WARM
You can watch and count to three, then it changes from cold → warm
We have had two fixtures from the Ecostat system for two years:
1x shower: works perfectly
1x bathtub/shower connection: the ghost fixture
If you are suspicious: it happens exactly after 2 years
and with a Hansgrohe fixture marketed as high quality
Or is this just a random failure?
=> Who has operational experience with Grohe Ecostat Select?
I look forward to your messages
Hansgrohe Service13 Oct 2015 17:28Hello Reiner IV,
I’m from the Hansgrohe service team and found your post here.
With a thermostat, hot water and cold water are always connected. This means that if the pressures in the supply lines are different, it can affect how the thermostat functions. Your description sounds like something in the basic conditions of the supply system has changed. The fact that this is not happening with the shower thermostat is probably because it is used differently. The adjustment likely only occurs when it is set to the coldest setting.
However, this is not a problem. Just contact us at the phone number 07836511282, and we can discuss everything, identify the cause of the issue, and, if necessary, provide you with the appropriate replacement parts. I believe it is just a minor issue.
See you soon and best regards,
Günther from the Hansgrohe service team
Many thanks to the Hans Grohe service team.
Great service, even when one colleague is on vacation, another steps in—excellent.
- The communication (phone as mentioned above) was competent and prompt.
- We were able to find a permanent solution.
Many thanks again.
Gladly choose Hans Grohe again—quality that pays off...
Greetings from Berlin
ReinerIV
Many thanks again.
ReinerIV
