ᐅ Positioning of the ventilation system, installation of the air intake and exhaust vents
Created on: 10 Jun 2021 10:47
K1300SIceman888 schrieb:
Does it make sense? Not really. It’s either all or nothing.
Iceman888 schrieb:
Is that a disadvantage? No, it just needs to be calculated, and the device selected or sized accordingly.
Iceman888 schrieb:
On which side of the house exterior wall are the supply and exhaust vents installed? That depends on the lunar phase. 😀 Just kidding. Since we usually have westerly winds here in Central Europe, it makes sense to place the fresh air intake on the west side and the exhaust vent on the north, south, or east side. Or the other way around: exhaust on the east and fresh air intake on the north, south, or west side. Apparently, there are also combination covers that allow both vents on the same wall without causing problems.
Our controlled residential ventilation system is located in the basement, with the supply and exhaust air outlet on the upper floor. A duct shaft is required for the pipes, which you will need anyway for the ventilation ducts coming down from the ceiling on the ground floor and upper floor.
Iceman88810 Jun 2021 16:30K1300S schrieb:
Not really. It’s either all or nothing.And why? According to Selfio, it doesn’t matter...
The problem is the
Iceman888 schrieb:air and temperature exchange. Additionally, the system is normally set to a slight positive pressure. However, this is not possible if the positive pressure is immediately equalized.
And why? According to Selfio it doesn’t matter...
Iceman88810 Jun 2021 22:44Okay. Won't I have a problem with condensation at that point? The basement is not heated!
